Engine runs rough
Old Oct 22, 2011 | 01:36 PM
dayscue's Avatar
dayscue
Engine runs rough
I have a 2005 F-150 stx 4wd with a 4.6L V8. My engine started running rough and my check engine light came on. I went to Autozone and they did a scan and said cylinder 5 was miss firing. I changed the plugs. I just took it for a drive and it still runs rough when I press the accelerator and when I turned on my drive way it shut off. I restarted and drove it down my drive way and parked it. Anybody have any ideas?
Old Oct 22, 2011 | 02:05 PM
jpurvis79bronco's Avatar
jpurvis79bronco
It could be the COP (Coil on plug), or sometimes the plug wire/boot will break down and arc across causing a misfire, Could be a number of things but try wrapping electrical tape round the number 5 plug wire to see if it was the culprit.
Old Oct 22, 2011 | 02:28 PM
dayscue's Avatar
dayscue
I put new boots on with the plugs. Is there anyway to check the cop before I buy one?
Old Oct 23, 2011 | 02:31 PM
jpurvis79bronco
With the engine running unplug and replug each individual coil to see which one may be causing the misfire. You can swap the cop with another cylinder to see if the misfire moves with it.
SoCalJim
1997 - 2003 F150
Nov 30, 2011 06:18 AM
brad1974
Modular V8 (4.6L, 5.4L)
19
Jul 12, 2005 03:26 PM
Justfishing
Mar 17, 2005 08:21 AM
ghinton
13
Mar 2, 2004 03:02 PM
97ExpyXLT
Jul 20, 2003 07:41 AM
