No Tail Lights
Old Dec 11, 2022 | 10:25 AM
Overkill2's Avatar
Overkill2
Thanks to the pioneers who found and identified this potential electrical harness issue
Originally Posted by Travo87
Hey so I had a feeling it might be a wire or harness issue after I checked the bulbs, fusees, and what not. I looked in the back of the truck where the tail lights are and couldn't see nothing wrong never expected it to be up front ill check mine out there hopefully that's it cause I ain't got no reverse lights either weird
Let us know what you find.
Since this WAS resurrected, I went out and checked mine because this was resurrected, I saw it and HAD to check mine...
Mine was rubbing VERY slightly and started rubbing off the sticker there... It does look like it's at least covered by tape but not sure of cable loom. I wasn't pulling it apart to see.
Piece of hose i used... Probably 3/4 ID...
Cut and slit open...
Rubber hose up and in place shielding harness from the wheel well piece AND the coil spring mount edge there.
Now my OCD concerns have been addressed....
tunahunter6614
Electrical Systems/Wiring
Jul 12, 2021 04:34 PM
huskyfan68
Apr 20, 2017 01:21 PM
jahollis2380
Jul 21, 2011 08:34 AM
bdunegan
Dec 7, 2006 01:36 PM
tvvbsn
1997 - 2003 F150
Nov 23, 2004 11:54 PM
