No tail lights?
Old Jul 21, 2011 | 06:44 AM
jahollis2380's Avatar
jahollis2380
No tail lights?
The other day my dash lights went out plus my tail lights!!! The number four fuse blows the fuse every time i put one in there. Im assuming they are both on the same fuse giving that my break lights work along with my blinkers and hazard lights? Any suggestions on places to check first? Thanks! 89 f140 with 5.0 auto
Old Jul 21, 2011 | 06:46 AM
KevinGnWV's Avatar
KevinGnWV
The village idiot.
Yes, your cluster lights and tail lights are on the same fuse. You have a short somewhere, most likely in the tail light housings or in the harness at the back of the bed. Also look at places like if you have a trailer plug in etc. Might also check the front marker lights inside the turn signal housing and cab clearance lights if you have those.
Whatever you do, DO NOT put a larger fuse or bridge the fuse holder. It will catch on fire. I'm sure you know this but I see it more often than you would think.
Old Jul 21, 2011 | 08:34 AM
jahollis2380
I found the short! frayed wire in the trailer connection wires!
TXtinct
Oct 17, 2012 10:01 AM
bar20
2004 - 2008 F150
Jul 13, 2010 08:48 AM
threeboysandadog
Aug 20, 2008 07:29 AM
idgit0488
Oct 25, 2006 01:13 PM
fred white
Aerostar
Nov 12, 2003 02:51 AM
