Possible bad alternator?
Old Oct 21, 2011 | 11:04 PM
Diesel 724's Avatar
Diesel 724
Question Possible bad alternator?
The other night my truck wouldnt start, the battery was dead. So i had to grab a jump needless to say it took one car for each battery to get my truck started. Then i got it started and drove down the road on my way home. I made it about a mile and my lights shut off and all my interior lights went out and my windows stopped working and everything. Then About a mile further my truck just shut itself off. Needless to say to i had to call AAA for a tow home. Does this sound like an alternator to you guys?
Old Oct 22, 2011 | 12:34 AM
big poppa's Avatar
big poppa
I think its rebuild time, find a reputable rebuilder and keep that stock unit, its a good one, guys told me here, I had mine rebuilt. Take it out and have it load tested, batteries too and you'll see where your at. Good luck.
Old Oct 22, 2011 | 03:42 AM
sand1's Avatar
sand1
i tried lookin for a rebuild kit to do it myself and cant find a kit anywhere
Old Oct 22, 2011 | 06:01 AM
blue1ton's Avatar
blue1ton
My original alternator on my 2002 F350 went up a few years ago. I ended up buying a Ford remain alternator from Ford. So far so good. I have heard that the remains directly from Ford are good quality, not like some remains from some of the auto parts chains.
Old Oct 22, 2011 | 07:00 AM
megawatt00's Avatar
megawatt00
I would say that she gave up the ghost. Where your batteries were drained that low I would look into replacing them as well. It is a cycle that happens, alt takes out batteries which take out new alt which take out batteries. I had mine go out in the summer and by late fall I was replacing the batteries.
Old Oct 22, 2011 | 10:44 AM
ToMang07's Avatar
ToMang07
Definitely take the batteries AND alternator and have them tested, but yes, sounds like it's shot. I would charge the batteries first and then have them load tested. If any doubt, replace them.
Old Oct 22, 2011 | 12:27 PM
driximus's Avatar
driximus
Every 2 years I was replacing batteries and Alternators. it is a angry cycle.
Old Oct 22, 2011 | 08:47 PM
Diesel 724's Avatar
Diesel 724
My batteries are only a year old and my alternator has been in my truck since i bought it 4 years ago.
Old Oct 27, 2011 | 05:07 PM
Diesel 724's Avatar
Diesel 724
I went to the junk yard the other day they said they had 3 of them. So i search and search and low and behold all 3 trucks had the motors out of them! 2 hours later! I found an 03 F350 with a diesel and the alternator wasnt located on the front right like mine in was more front/middle on the left! Can anyone tell me why it was different?
Old Oct 27, 2011 | 05:33 PM
Kajtek1's Avatar
Kajtek1
The difference might be that the other diesel is 6l.
Your TRUCK might have bad voltage regulator. Nobody says "bad truck" where there is no charging, but they say "bad alternator" when the brushes are out.
How many miles?
Old Oct 27, 2011 | 05:38 PM
Diesel 724's Avatar
Diesel 724
Around 160K
Old Oct 27, 2011 | 06:10 PM
Tailgate77478's Avatar
Tailgate77478
Whatever you do with the alternator, voltage regulator, etc...make sure you've trickle-charged both batteries back up to full before you start your truck. Don't "charge" your low-to-dead batteries with the alternator...it puts a lot of strain on the alternator, and will reduce the life of a new alternator if it's first use is a heavy load like that.
Ditto on getting your batteries load-tested somewhere too.
Old Oct 27, 2011 | 09:35 PM
Kajtek1's Avatar
Kajtek1
160 amp alternator should handle charging the batteries just fine, but batteries don't like to be charged at such a high current and overheating them will shorten the life. The best is 10 amp per battery for charging.
Brushes or voltage regulators are hard to buy separately, so if you can wait, order them from a dealer, if you need the truck tomorrow, you might be forced to pay for whole new alternator.
Trav1990
Nov 6, 2016 09:29 PM
keating8070
Sep 7, 2010 05:43 PM
Buck200x
1997 - 2003 F150
Jul 28, 2009 08:38 AM
tbart16
Jan 16, 2007 01:18 PM
93 Ford F-150
Aug 15, 2005 06:47 PM
