Quick Tach Question
Intermittently on and off... Mostly off. I checked the tach signal from the coil to the cluster and it checked good. Checked the power and grounds... all checked good. Checked the ohmage of wiring, all checked good.
I saw in a t/s guide to check the fuse for the tachometer... where is the fuse for the tach? I've looked in both fuse boxes with no success...
Could it be a dead tach, and is there a way to fix that or should I stop wasting my time on this? Thanks a bunch in advance.
