Tach Troubles
Old Jun 20, 2003 | 01:16 PM
1986f2504x4's Avatar
1986f2504x4
Tach Troubles
Just put a used tach on my 86 f 250. Hooked it up to the neg. side of the coil, and to the ignition fuse. But the problem is when you rev the engine it jumps right up to 8000 and i know my engine don't rev that high. Is there a way to calibrate the tach, or an adjustment i can make. The tach is pretty small, maybe 2-3in diameter, it is also pretty old.
Old Jun 20, 2003 | 01:49 PM
loudfords's Avatar
loudfords
Tach Troubles
Is there a 4-6-8 switch on the back of the tach? Most aftermarket tachs have this to calibrate it to the number of cylinders your engine has.
Old Jun 20, 2003 | 03:52 PM
1986f2504x4
Tach Troubles
It did have one. It works perfect now. Thanks for your help.
Old Jun 23, 2003 | 11:32 AM
loudfords's Avatar
loudfords
Tach Troubles
No problem!
