thinking about getting a 460... help please
Old Oct 24, 2011 | 11:18 AM
  #31
peter_x's Avatar
peter_x
Commercial plates are only required in NY if the vehicle is over a certain GVWR (which IIRC is 8500) and is primarily used for work purposes. You can take an F-350 with passenger plates on parkways without a problem.
Also, I think NY lists curb weight on titles. When I registered an F-SD wrecker, they told me I had to list the weight as only 4,500 (I guess that's the weight of the chassis cab). Then they asked me what I wanted to have as the GVWR on the registration... you can tell them anything apparently. They don't care what the wrecker weighs as long as your gross is under the registered amount. The wrecker body itself is part of the "load".
Old Oct 25, 2011 | 07:50 AM
  #32
Diesel_Brad's Avatar
Diesel_Brad
Originally Posted by peter_x
Also, I think NY lists curb weight on titles. When I registered an F-SD wrecker, they told me I had to list the weight as only 4,500 (I guess that's the weight of the chassis cab)..
Your BARE cab-n-chassis weighs closers to 6-7000
Old Oct 25, 2011 | 08:14 AM
  #33
peter_x's Avatar
peter_x
Sounds quite heavy. That's what they told me I had to list after they looked it up in there system.
The entire truck tares at about 9500 without tools or driver. I think 4500 for the chassis cab and 5000 for the wrecker body sounds about right.
Oh and it's not a diesel... it's a 460.
Old Oct 26, 2011 | 07:28 AM
  #34
Diesel_Brad
This trick weighs 7,000 as you see it. It is a diesel but they are only 200lb more than a 460
Old Oct 26, 2011 | 08:18 AM
  #35
peter_x's Avatar
peter_x
I guess I am a little heavier than I thought. I can't tell what the CA is on that truck... mine is 60". How did you get all those leaves in the back? My '88 only has two in the top part and I think 5 in the main section.
Old Oct 26, 2011 | 10:44 AM
  #36
Diesel_Brad
It is a 137" WB. The truck was a Former Oil Delivery truck w a 800 gallon oil tank on the back(tank, oil, pump weighed 6,800) so they took it to a spring shop and had extra leafs added. Doesnt really matter though. Truck was only rated for 11,000 and that is all you could legally haul with it, but everyday they went out weighing over 13,000. Then there was a 9' plow that hung off the front weighing another 1000lbs
Highmark18
All Things Towing
51
Jan 16, 2022 11:55 AM
f1bguy
Mar 20, 2014 02:41 PM
1994F2507.3L
40
Dec 26, 2010 11:11 PM
onelugnut
6.4L Power Stroke Diesel
24
Jun 1, 2008 12:08 PM
Ferguson65
2004 - 2008 F150
Oct 18, 2006 08:43 PM
