5 Questions.
Old Oct 20, 2011 | 10:22 PM
4x484150's Avatar
4x484150
5 Questions.
Here goes everyone.
First, where can I get the 194-G bulbs for the dash other than the internet?
Second, I should cut out part of the rad core support so I go from a 300 size radiator hole to the V8 size right?
Third, I should get a fan shroud correct?
Next, I was working on my rear brakes, and I noticed my driveshaft was not perfectly straight. Is this something to worry about? The shifter shakes at highway speeds.
Finally, I have a mismatched cab and frame. From the same year and plant actually. But I don't know what gear ratios I have in front or back. What's the easiest way to tell?
Thanks in advance.
Old Oct 21, 2011 | 03:33 AM
Ken Blythen's Avatar
Ken Blythen
I can help with some of your issues.
1. Don't know regarding these - I'm in New Zealand
2. You will need the bigger core - I guess if a V8 support isn't available, then cutting is an option. LMC, & probably others, do have reproduction supports.
3. Correct - I wouldn't neglect this - it makes a big difference to cooling efficiency, especially at lower road speeds.
4. I wouldn't neglect this either - apart from the droning & vibration, it's harder on the carrier, tailshaft, & pinion bearings. Long-term it can also become dangerous.
5. For an open axle (non-limited slip).......
Jack up one wheel, with the transmission in neutral (or the transfer case when checking the front axle), then mark both that tire, & the driveshaft with chalk.
While turning the wheel 1 turn (360 degrees), count the revolutions that the driveshaft makes. Double that number to get your axle ratio.
e.g. If 1 turn of the wheel gives you -
1.75 turns on the driveshaft x 2, = 3.54:1 axle.
Or 2 turns on the driveshaft x 2, = 4.11:1 axle
Or 1.5 turns on the driveshaft x 2, = 3.00:1 axle
If you have a limited slip axle & have trouble spinning the wheel freely, jack up & turn BOTH wheels 360 degrees together (easiest with two people), but DON'T double the driveshaft count. This will then give the correct ratio.
Old Oct 21, 2011 | 10:40 AM
4x484150's Avatar
4x484150
Thanks Ken Blythen. As a little side note, the hole in the radiator support looks like it has the V8 size hole, just with a sheetmetal filler, as the truck originally had the 300. Also, to anyone, is the junkyard the best bet for the stuff I need?
Old Oct 21, 2011 | 02:06 PM
mblayton's Avatar
mblayton
Yes a junk yard would yeild the bulbs for the dash, almost any car/truck of that era will be the same.
Old Oct 28, 2011 | 10:45 PM
4x484150's Avatar
4x484150
So is there a store one could go to, to get the green bulbs I mentioned earlier?
Old Oct 29, 2011 | 08:11 AM
fellro86's Avatar
fellro86
They do make covers that you can put over the standard 194 bulb as well. I know they have the blue and rad, have to check on the green.
mblayton - he's looking for green 194 bulbs, not the clear ones.
Old Oct 29, 2011 | 09:19 AM
ctubutis's Avatar
ctubutis
There is a Pep Boys near me that has a selection of that kin of stuff.....
Old Oct 29, 2011 | 10:54 AM
Galendor's Avatar
Galendor
I have seen those green bulbs at both Autozone and Advance Auto...
Old Oct 29, 2011 | 11:33 AM
NWF150's Avatar
NWF150
I live in the Northwest in a small town,600 people, and I was able to get mine at Napa,then I found them at Autozone as well. Best of luck.
Old Oct 29, 2011 | 04:11 PM
fellro86's Avatar
fellro86
The ones at Autozone are Blazer brand, and are actually 168 bulbs, which will work fine for an instrument cluster. The covers are no longer there, just the bulbs with the color already on them.
Old Oct 29, 2011 | 07:10 PM
Greyf100's Avatar
Greyf100
i took out my 300 rad and put in a 302/351 rad and didnt change a thing, dropped right in.
Old Oct 29, 2011 | 07:38 PM
4x484150's Avatar
4x484150
Thanks for the help guys. And Grey-I also put in the 302/351 radiator, I was just wondering if the hole was big enough for cooling purposes.
Pladsmand
Feb 11, 2018 11:30 PM
Lizard XJ
Modular V10 (6.8l)
May 11, 2008 07:20 PM
ech0sh4y
Offroad & 4x4
73
Apr 5, 2008 12:13 AM
ljbrown
All Things Towing
Mar 22, 2007 12:11 PM
jdawwg
Offroad & 4x4
May 14, 2001 05:54 PM
