frame flex need some help
Old Oct 23, 2011 | 07:27 PM
mike83f250's Avatar
mike83f250
i have a 82 f250,it has a lot of frame flex at the crossmember.there looks like a bolt that bolts the farme to cross member,but i cant figur out how to get to it.it between the steering box and oil filter.
Old Oct 23, 2011 | 10:08 PM
dohc_chump's Avatar
dohc_chump
This space for rent...
I believe it's half rivets and half bolts. Ladder frames by their very nature are flexy. You can use box tubing and make a brace for the front and rear frame horns to help reduce some of the flex. Keep in mind some of the flex you see is also due to lack of articulation in your suspension.
Old Oct 29, 2011 | 08:28 PM
mike83f250's Avatar
mike83f250
is there any way to replace that bolt
Old Oct 30, 2011 | 10:26 AM
Diesel_Brad's Avatar
Diesel_Brad
Need a pic. but if the oil filter is in the way, just remove it
watersurgeon
Oct 19, 2018 06:03 PM
Bigdon68
Dec 14, 2016 03:44 PM
79_FORD_F-100
Sep 30, 2012 09:29 AM
dilyb
Feb 12, 2009 08:30 AM
460
Mar 21, 2006 01:24 PM
