1978 - 1996 Big Bronco
Tire Recommendations
Old Apr 11, 2003 | 04:26 AM
mbuthey's Avatar
mbuthey
Question Tire Recommendations
Hi guys,
First thing, I'm new in restoring trucks, but like it.
I've got an '82 Bronco with, I believe, 15x8 wheels. Can first someone tell me if it's correct.
What's the biggest tire size I can put on those without lift ?
I wanted to have 33x12.5 15 instead of the 31x10.5 15 I have now.
About the lifts, can I put a 3'' body lift from Summit or anywhere else with doing anything else ? Or do I have to change the springs, ... ?
Thanks for your help.
Marc Buthey
Bronco lover from Switzerland Europe
mbuthey(No Email Addresses In Posts!)
Old Apr 11, 2003 | 10:11 AM
treehugger36's Avatar
treehugger36
AMEN Greystreak!
USA! USA! USA! USA!
Those French pigs will get what they deserve (i.e.-> Us not giving them more money when they have some stupid national crisis) We need to ask for our money back!
and just to make sure this stays on subject....
I have small tires and I want 33's... how does everyone feel about Procomp?
Old Apr 11, 2003 | 12:32 PM
Wakeboarder141's Avatar
Wakeboarder141
I had a set of 31x10.50 Bridgestone Dueler A/T and they rode like a dream. Pretty decent in the sand. No noise, and at 60k miles they still had about 70% tread left.
Old Apr 11, 2003 | 12:44 PM
greystreak92's Avatar
greystreak92
mbuthey,
Most tire manufacturers recommend at least an 8" wide rim for 12.5" wide tires. As to whether 33x12.50's will fit under the truck in stock form, I don't know. But adding 3" of lift either body or suspension I would think should let them swing very nicely under your 82. Again, not certain as to the width of your rims. But I think they should be 15x8". The 15x7.5" were on later models as I recall.
A body lift will not require ANY suspension modifications. Body lifts simply push the body up away from the frame. The suspension can remain stock if you want.
Old Apr 11, 2003 | 12:51 PM
mrwizard's Avatar
mrwizard
Since I started the "don't buy french tires" thing, let me ask, did you notice the little 'smiley' next to my comment? Boycotting a french owned company because of the french governments idiocy would be about the same as boycotting McDonald's because you don't like to pay your income tax. Doesn't hurt the government at all, just the company.
Marc, 33X12.50's may or may not fit with the stock suspension. I had them on my '85 with the stock setup (except wheels), and they were fine. They would just barely rub on the radius arms at full turn, but that was not a big deal. I think a lot depends on the individual truck, and how much the thing has settled over the years. As far as the wheels go, most manufacturers don't recommend putting a 12.5" wide tire on anything less than an 8.5" wide wheel. Yes, they will probably work just fine on an 8" wheel, and even seem to fit OK an a 7.5", but you risk having the tire break off the bead if you're doing any serious off-roading. Plus, having any tire on a wheel that's too narrow will cause the tire to wear unevenly.
Old Apr 11, 2003 | 01:37 PM
treehugger36
yeah, I realized you were just joking around. I was just givin you a hard time. but you have to admit, there are ignorant die hard patriots out there that are that bad.
Anywho, just givin ya hard time. Sarcasm doesnt come across to well in a forum like this....
Peace...
Old Apr 11, 2003 | 04:47 PM
mrwizard's Avatar
mrwizard
No problem, I had Freedom Fries with lunch!
Snowseeker
Aug 4, 2014 08:21 PM
TreySmith
19
Nov 6, 2010 10:50 AM
bryanswens
27
Sep 25, 2010 11:33 PM
79F150EFI
Aug 27, 2007 06:33 PM
closetredneck
17
Jul 11, 2006 08:04 AM
