Fuel Filter replacement ?
Old Oct 19, 2011 | 08:02 AM
knsahara's Avatar
knsahara
1 is it ok to get the fuel filters aftermarket from the autoparts store ?
2. Is there a recommendd procedure when changing them?
Thank You.
Old Oct 19, 2011 | 08:12 AM
npccpartsman's Avatar
npccpartsman
I would recommend that you do NOT get them from an autoparts store UNLESS they have the white aquabloc membrane on the primary (large) fuel filter which aids in water removal from the fuel. Dieselfiltersonline.com has great prices on factory fuel filters as does an IH dealership. The procedure should be in the tech folder at the beginning of the 6.0 forum.
Old Oct 19, 2011 | 08:28 AM
knsahara's Avatar
knsahara
ok thank you I'll check that out.
Old Oct 19, 2011 | 09:26 AM
69cj's Avatar
69cj
Motorcraft or Racor only. Don't cut corners here or with the oil filters. It can cost a lot more in the long run.
Old Oct 19, 2011 | 11:01 AM
zhilton's Avatar
zhilton
You can also use Navistar/International branded filters, they're made by the same folks that make the Ford/Motorcraft (Racor). As pointed out above, if you can wait a couple of days...Diesel Filters Online is by far the best place to get the filters. The savings stack up the more your order at a time. And if you've got the $$$ laying around to get a $250 order together, the shipping is free.
Old Oct 20, 2011 | 12:27 AM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Dear Opening Poster,
aftermarket filters do not fit 100% (no matter what the company's marketing states or what the store salesman tells you).
Racor is the OEM manufacture of the filters and the housing (oil and fuel). Using non OEM made filters will not fit and perform 100% for obvious reasons (the filters were designed to fit the housing. To get around the patents on the filters, "will-fit" filter company's have to change something as not to violate the patent (enough said).
The advice that has been given in prior posts is 100% accurate. I personally buy by filters at the local Int'l truck dealer for 1/2 what the Ford dealer sells them for!!!
I do not have the IH fuel filter number handy... but asking for the filter that fits the 6.0L or VT365 will get you the WRONG filter (Int'l uses a different fuel filter on their motor).
Buy Motorcraft oil filters at Walmart for $19.00 or so (best price around and easy to buy 1 at a time as needed).
Old Oct 20, 2011 | 04:41 AM
zhilton's Avatar
zhilton
Oil Filter:
Navistar 1840752C91
Racor FL-2016
Ford/Motorcraft 3C3Z-6731-AA
Fuel Filter:
Navistar 1847170C94
Racor PFF4616
Ford/Motorcraft 3C34-9N074-BA (I think that's the new part number)
With either the fuel or Oil filter...all three of those numbers are the exact same filter. Only the package and $$$ are different.
Old Oct 20, 2011 | 06:27 AM
bismic's Avatar
bismic
I believe the new fuel filter motorcraft # is 3C3Z-9N184-CB
Old Oct 20, 2011 | 11:13 AM
Cowboy65's Avatar
Cowboy65
Follows is a link to the official Motorcraft Fuel Filter change procedure:
http://www.dieselfiltersonline.com/D...ence-Guide.pdf
CorkyNM
6.4L Power Stroke Diesel
16
Feb 6, 2011 11:36 AM
kopjs
Sep 24, 2009 06:04 PM
61 uni
Dec 31, 2008 12:29 PM
atvraptorman
Sep 25, 2006 12:13 PM
Rich in CO
May 14, 2005 12:20 PM
