New Guy
Old Oct 18, 2011 | 08:03 PM
trooper99's Avatar
trooper99
New Guy
Hey, I have 93 4x4 EXT cab, that I bought with 6'' lift and 35x12.5xr15 on it. I love look but gas mileage is killing me. Was wonderring if you guys had any ideas as to what size I could drop down too and still look good. Any ideas would help. Also what year factory rims will fit my truck as well.
Old Oct 18, 2011 | 09:55 PM
bashby's Avatar
bashby
F150, 250 or 350? What engine/ trans?
Old Oct 18, 2011 | 10:04 PM
Beatertruck's Avatar
Beatertruck
Has it been regeared? A little more info would help and welcome to FTE.
Old Oct 19, 2011 | 06:25 AM
trooper99's Avatar
trooper99
Sorry, F150. Not sure if it has been regeared.
Old Oct 19, 2011 | 08:27 AM
Conanski's Avatar
Conanski
With tires that much larger than stock your speedo is off quite a bit, according to one online calculator when the speedo is showing 49mph you're actually going 60 so you're pushing the truck faster than you think and burning more gas as a result. This also means the odometer is showing fewer miles driven than actual so fuel consumption calculations will look artifically low. You can fix all that by recalibrating the speedo, follow the link and complete the procedure.. HOW TO RECALIBRATE THE SPEEDOMETER ON 92-96 FORD F-SERIES AND BRONCO .: Articles
As for axle gearing, these trucks really aren't geared to handle that big a tire so a gear change would certainly help, but if you're going to drop down to 31's or 32's and the axles have 3.55's then that's probably OK, not great but better than what you have now. You should find the axle code on the drivers door decal and a list of what that translates to here... Ford Axle Code Chart .: Articles
Ultimately for best fuel milage you'll need to lose the lift completely, the higher the truck the more gas it'll burn, but if you don't do a lot of huighway driving it won't have as much impact.
Old Oct 19, 2011 | 10:30 AM
hammerhead90's Avatar
hammerhead90
Better gas mileage? buy a cheap car instead of a different lift and tires
Mike_78SuperCab
Feb 18, 2014 07:25 PM
sari58
Nov 7, 2010 05:16 PM
ehonda
Jan 19, 2007 03:12 AM
Meat58
2004 - 2008 F150
Oct 2, 2004 07:58 PM
sportquad racer
Sep 9, 2004 11:16 AM
