Steering characteristic
Old Oct 18, 2011 | 05:50 PM
FTE Herman's Avatar
FTE Herman
New 2011 ~1,000 miles. When traveling the I in the left lane, I actually need to maintain slight clockwise input to keep going straight; when in the right lane, the truck tracks as I would expect, but the wheel is a 'few degrees' clockwise of 'perfect'.
Had it in for an alignment and nothing has changed.
Is this simply a characteristic that I should accept?
Old Oct 19, 2011 | 06:30 PM
FTE Herman's Avatar
FTE Herman
Excuse me, but you guys do drive these things don't you?
Old Oct 19, 2011 | 06:38 PM
powerstroke72's Avatar
powerstroke72
Sorry I didn't see this before now Herman. If this is just occurring when you're in the left lane (pulling, that is), I would almost think that it might be a road characteristic such as the crown of the road.
As far as the wheel being a little off when in the right lane, I'm not sure why it's like that and I've never noticed it on mine. Geez, I'm going to be checking that now.
Old Oct 19, 2011 | 06:42 PM
FTE Herman's Avatar
FTE Herman
Thanks John, I was thinking crown-of-the-road as well; however, this wasn't an issue in my Navi and other Ford cars.
Old Oct 19, 2011 | 06:46 PM
powerstroke72
I notice a huge difference between this truck and my wife's Denali on the same roads too Herman. I do believe that there are certain characteristics of the steering in these trucks that take a little getting used to and aren't "the norm". I will say that the steering on this truck is better than that of the 2005 F-250 I had prior to this 2011.
Old Oct 19, 2011 | 06:52 PM
cirrus365's Avatar
cirrus365
I have noticed this as well but ever slightly pull to the right.
Old Oct 25, 2011 | 10:55 AM
markiemark's Avatar
markiemark
Herman,
I had to take mine back to ford about 5 or 6 times to get it to stop pulling to the right. After two alignments, a replaced tire, and a replaced rim, it was still pulling. My steering wheel also was not pointed straight when traveling straight. Ford ended up calling a FSE and he recommended changing caster degree. He took out original casters and replaced with 1 degree casters and now truck tracks pretty straight. All of the technical stuff way over my head but hope that it may help your situation. Thanks, Mark
Old Oct 25, 2011 | 11:09 AM
CascadeF250's Avatar
CascadeF250
I have noticed my 2011 does the same thing. It will actually pull slightly the way the road is sloped either to the left or right. My 2001 F250 did the same. I felt this was normal behavior and not a problem.
Old Oct 25, 2011 | 11:54 AM
brandon4's Avatar
brandon4
Its a result of the solid axle I believe.
Old Oct 25, 2011 | 12:59 PM
EpicCowlick's Avatar
EpicCowlick
I personally feel the SD steering is a little over-assisted and under-castered. It gives the feeling of looseness and wanders in the lane a little on the freeway. This is exacerbated by lifting or leveling but provides a great opportunity to make it steer the way the driver prefers. For me, I added extra caster and steering stabilizers. It tracks straight and the steering is firm now. Just the way I like it!
Steve Lee
Oct 26, 2017 03:33 PM
GuyPavelo
Aug 9, 2013 09:21 PM
Bat-Masterson
Jun 8, 2011 10:28 AM
Holbrook
Oct 22, 2004 07:55 PM
