Seriousely...between o and 10 psi it just like flutters the whole time and if I mash on the go pedal it'll try to flatten out but not really..I tapped it into the map line but I wonder if I got a problem somewhere
So basically I just need to choke down the size of the tee going to the guage at the map connection..I wonder if this is happening because of the size of he vacuum hose I chose
Or something like this, but not necessary this exact one ...
Welp guess ill just go order that tomorrow..what a pain in th ***
couple years ago i had an 02 subaru wrx fuuun car anyways i put a boost gauge in it and it would flutter like crazy to i was think hmmm wtf so i moved the line to the bov line worked after that fine, but could be the size or set you have
