Sponsored by: Auxito
4.6L Gotts Mod
Old Oct 16, 2011 | 11:47 AM
ChambersF150's Avatar
ChambersF150
Thumbs up 4.6L Gotts Mod
I just completed the Gotts Mod on my 2001 4.6L Supercrew.
I feel a noticeable difference in top end power, it pulls quite nicely.
The mod took all of about an hour and a half from getting the materials at Home Depot, to starting up the truck and test driving it.
I would gladly recommend this cheap modification to anyone looking for more power out of their 4.6L 2V V8.
Let me know if you have any questions! And I'll try to answer them
Old Oct 16, 2011 | 04:01 PM
muddyford911's Avatar
muddyford911
good deal. i did the gotts mod to my 5.4 a few months back. i cant say i noticed much of a difference. i disconnected my battery the entire time i was doing the install. oh well, its always fun tinkering around.
Old Oct 31, 2011 | 10:24 PM
lndianScout's Avatar
lndianScout
I live in ND no need for a cold air mod
Old Oct 31, 2011 | 10:34 PM
ravens fan's Avatar
ravens fan
what are the details of this mod?
Old Nov 1, 2011 | 12:12 AM
ChambersF150
Search for "Gotts Mod" in the search bar and the original thread should pop up. It's a fairly simple rebuild on your intake opening from the fender well. I'm not sure of where the original thread is, but someone should know.
Old Nov 1, 2011 | 08:35 PM
steve(ill)'s Avatar
steve(ill)
basically the intake tube goes thru the fender well and sucks cool air into the intake manifold. The plastic intake tube has about a 2.5 inch hole in it and it pokes thru a 3.5 inch hole in the fender well. You eliminate the plastic tube and replace it with a 3 inch PVC pipe coupling that butts up against the 3.5 inch opening in the fender--- same cool suction ,but about twice tha air intake. You get a slight increase in "rumble" or engine nosie which does sound good, not objectionable. Lets the motor breath a little better which in theory should help... but remember, your running down the road at 1600 RPM and probably had about enough air already for that RPM.. STill it is cheap and "might" help. I did it several years ago to reduce any intake restriction that "might" exist.
Old Nov 1, 2011 | 08:39 PM
steve(ill)'s Avatar
steve(ill)
click on my name next to the tractor photo... then click on "galary", then clich on the blue title "intake tube" to see a bigger photo of the stock inlet tube.
Old Nov 3, 2011 | 09:31 PM
Bear 45/70's Avatar
Bear 45/70
All the new trucks and cars come with a CAI system. What this mod does is opens up the restriction on the fender side of the air filter.
tritonman2001
Oct 23, 2010 06:39 PM
THEDON117
Oct 31, 2008 11:03 AM
powerstrokeddiesel
Jun 22, 2007 11:27 AM
bigbadwolfe
Jan 18, 2007 07:17 PM
