Ccv reroute issue
Old Oct 16, 2011 | 11:35 AM
j4henry's Avatar
j4henry
Ccv reroute issue
Well I finally had enough with oil in my turbo tubes so I did a ccv reroute. I ran it to a filter setup that l had seen someone else use where it comes in the center through a screen and back out then I ran on out towards the rear of my excursion and placed a crankcase filter on the end of the tube. I towed my camper 3 hours and when I arrived I found that from oil pan back is covered in oil spray!! So I figure I'm building too much crankcase pressure but my setup is identical to a few I've seen what did I do wrong? Should I leave the filter off of the end of the hose? Or should I Run hose back up to air intake? I'm on the road so I can't post pics til tomorrow. Thanks In advance
Old Oct 16, 2011 | 11:51 AM
cartmanea's Avatar
cartmanea
Could be too much restriction with the dual filters. Can you locate where the oil spray came from? Also, if your CCV tube has a low spot in it, oil can collect there and choke it off.
Old Oct 16, 2011 | 02:05 PM
Mich6.0's Avatar
Mich6.0
run it through the first filter and straight to the ground and forget about the second breather filter it will not suck back to the motor, the engine builds pressure not vacume
Old Oct 16, 2011 | 02:24 PM
j4henry's Avatar
j4henry
Looks like maily rear seal location or the plate between oil pan and block. It's everywhere but just a mist cover not dripping anywhere. guess I don't have to worry about rust this winter.
I took scone filter off and I'm going to shorten the first hose and housing about 2'. Right now I have it mounted in front of rear drivers side tire.
Old Oct 27, 2011 | 01:55 PM
j4henry's Avatar
j4henry
well i fixed my reroute issue BUT it is still spewing oil all underneath the ex and my tt. I cleaned everything drove it back home and found that there is a puddle of oil inside the bellhousing behind the inspection plug, and the oil pan is leaking on the rear of the motor. Only the bottom half of the bell housing is wet from oil from the starter up on the bellhousing is dry. so my question is it more likely the rear main or something to do with the hpop? I only sprays the underside of vehicle if i am towing. Im trying to get an idea before i start taking apart on saturday THANKS
Old Oct 27, 2011 | 02:01 PM
steelhead2's Avatar
steelhead2
03?,could it be running down from the back of the block from the ipr?.did it start this right after your ccv re-route?.
Old Oct 27, 2011 | 02:37 PM
cartmanea's Avatar
cartmanea
You probably mean ICP, it's the one that leaks.
Old Oct 27, 2011 | 03:10 PM
j4henry's Avatar
j4henry
It has always had a little in there but it has gotten real bad about the time I put the reroute in woult the ICP pool up inside the bell housing?
Old Oct 27, 2011 | 03:41 PM
cartmanea's Avatar
cartmanea
It sounds like you lost a rear main or bedplate seal if it's inside the bellhousing. Have you confirmed it is motor oil and not ATF? Could also be a front tranny seal.
Old Oct 27, 2011 | 04:00 PM
j4henry's Avatar
j4henry
unfortunately the diesel tech and the dealer "whom I've come to become good friends with because my wife is his baby's doctor" has confirmed oil is the liquid but he's not sure where to start until he gets a closer look it was dusk when he was looking but he feels its rear main but I've been looking and searching for two days and am more confused so we are going to start by pulling trans this weekend and look around I'll take pics once it it is removed and get some more opinions. Thanks for replies guys
Tul01
15
Oct 19, 2017 07:18 PM
ConvertedFord
Feb 13, 2010 08:28 PM
6litrefan
Mar 9, 2009 01:01 PM
Locopower
Feb 21, 2007 07:45 PM
AlaskaF350PS
Aug 28, 2006 09:04 PM
