Oil ?????
Old Oct 27, 2011 | 09:51 AM
j-bar's Avatar
j-bar
Oil ?????
Never used rotello t 6 5w 40 just wondering if its ok in a 6.0 powerstroke.
Old Oct 27, 2011 | 10:09 AM
zhilton's Avatar
zhilton
Yes, as long as your using CI-4 or CJ+ rated oil...it will be fine. There are allot of guys in colder climates that use Rotella T6 5W40.
Old Oct 27, 2011 | 10:51 AM
egregg57's Avatar
egregg57
I have been using Rotella for the past year here in NH. My truck and I both like it very much!
Old Oct 27, 2011 | 12:13 PM
j-bar's Avatar
j-bar
Is there any oil any better than rotello t6.
Old Oct 27, 2011 | 12:29 PM
zhilton's Avatar
zhilton
That's a can of worms your fixing to open...
I'm happy with the synthetic blend Mystic I'm running. It's $11 a gallon at my local farm/ranch store, meets the specs and the truck runs fine with it. Some guys will say Valvoine Synthetic Blue is better, other will say nothing is better than Rotella. Basically, like the style socks & underwear you wear...it's a matter of opinion. As long as the oil meets the required specs and doesn't cause damage (like Delco, don't think it's recommended)...the brand oil you run is up to you. The only thing that can't be stressed enough is OEM spec fluids & filters (Ford/Motorcraft, Racor, International/Navistar) is the only thing you should run in these trucks...PERIOD. And change 'em ontime; the 6.0L will bite you if you forget.
(I'm some what serous about that)
Old Oct 27, 2011 | 01:57 PM
jetact's Avatar
jetact
Mobil 1 Synthetic Turbo Diesel. Switched last year and it seems to be working fine and have good starts.
Old Oct 27, 2011 | 02:06 PM
dakotajeep's Avatar
dakotajeep
x2
Oil gets discussed super frequently. If you have time do a quick search and you can read through dozens of threads about it. It will amaze you.
I run Rotella T6 5W-40 by the way. So far I am not impressed but it may be the fact that the fuel is changing to winter fuel simultaneously with the oil change....time will tell.
Thad
Old Oct 27, 2011 | 02:16 PM
Special Ed's Avatar
Special Ed
Another one here for Mobil 1 Synthetic Turbo Diesel 5w40 every 5K
Old Oct 27, 2011 | 05:43 PM
j-bar's Avatar
j-bar
Ok thanks for the input.
Firefighter 1406
Feb 15, 2017 12:27 PM
southbound35west
Mar 28, 2009 12:00 PM
paul horvath
Jan 21, 2007 07:23 PM
cobarjet
Jan 1, 2007 11:34 AM
mefsh
Oil & Lubrication
Sep 5, 2001 10:15 AM
