EGR Cooler Block Off
Old Oct 30, 2012 | 12:34 PM
Billyboy21's Avatar
Billyboy21
I haven't had any issues with my egr cooler except having it replaced at 55,000 miles. Now the truck has 110,000 miles..so far so good, but I' like to lower my egt's, and help my hp. I'm running a SCT programmer set to 65hp towing since I tow a 40' lowboy for work. Why couldn't I just install a puck on the egr inlet side, and use the tuner to clear the egr codes.
Old Oct 30, 2012 | 12:59 PM
Idahoser's Avatar
Idahoser
I think the earliest flash(es) for '05 are like the earlier years, my truck has the EGR valve disconnected, and I don't have a CEL and my fan works fine.
Old Nov 1, 2012 | 09:42 PM
2112's Avatar
2112
Originally Posted by BLADE35
For you guys that have the EGR Valve unpluged Id be for plugging it back in
the EGR Valve needs to be plugged in for fan operation
Guys have reported that the Fan didnot work at all fan steps with the valve unplugged
and sometimes the egr deleate wont actully light up the CEL but does have a code there
Can you change the fan setting and turn off the codes with a SCT tuner?
Old Nov 1, 2012 | 09:46 PM
cheezit's Avatar
cheezit
do a search here for "side effects of disconnecting egr valve"
Old Nov 1, 2012 | 09:49 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Here you go, I book marked this one!!
https://www.ford-trucks.com/forums/9...egr-valve.html
Jimbo532
Jul 16, 2013 04:13 PM
04scurs
Mar 19, 2011 05:02 AM
Jbru167
Dec 7, 2010 04:24 PM
glm racers
Oct 3, 2008 12:00 PM
