EGR Flow and....
Old Oct 2, 2008 | 11:23 AM
glm racers's Avatar
glm racers
EGR Flow and....
if I plug up the cooler at the y-pipe, and leave the EGR valve connected, will I get a CEL?
More specifically is there a exhaust flow sensor that measure the EGR flow? or is the flow implied by the EGR valve?
Moreover, when I block the flow to the cooler, will that mitigate the risk of a failed cooler??
I have a 1/2/03 with 74k miles and I'm planning on blocking the exhaust at the y-pipe to avoid cooler failure.
Old Oct 2, 2008 | 11:34 AM
BowTieHatr's Avatar
BowTieHatr
you have the round egr cooler and those hardly ever fail.
Old Oct 2, 2008 | 11:42 AM
JIM_C's Avatar
JIM_C
There are different kinds of EGR coolers? I learn something new every day around here!
What are the different kinds?
I have a May build 03, do I have the round cooler as well?
Thanks BTH.
Old Oct 2, 2008 | 11:44 AM
glm racers's Avatar
glm racers
So should I worry or not?
I use my PSD for towing my toy hauler and for long distance travelling and so far it hasn't leaked any coolant, but (and there's always a but) after reading all these threads I'm now worried about damage from a f-in cooler leak, and my warranty is long gone.
I've kept mine bone stock, but this years I've had three P0401 codes, which I assume that the EGR valve is all gummed up. I've never removed the damn thing but if I'm going to I might as well manage my time and block off the cooler as well??
Thanks BTH
Old Oct 3, 2008 | 06:44 AM
BowTieHatr's Avatar
BowTieHatr
i believe so jim but you can look and see to make sure.
glm, those early trucks throw egr codes easily due to the inferred ebp reading. if you have no lack or loss of power then dont let it worry you.
Old Oct 3, 2008 | 07:14 AM
HeavyAssault's Avatar
HeavyAssault
You will get a CEL, try unplugging the EGR valve and see what happens. If you don't get the CEL, then block the pipe and unplug the EGR valve. EGR is commanded by the PCM for operation. You will prevent the possible flash boiling of the coolant inside the EGR cooler preventing failure.
Old Oct 3, 2008 | 11:57 AM
glm racers's Avatar
glm racers
glm = Gil,
I don't experience any performace problems when P0401 occurs, so I'm happy.
Thanks BTH
Old Oct 3, 2008 | 12:00 PM
glm racers's Avatar
glm racers
Good point. I'll try that.
I would like to bypass the damn thing, but I'm hearing that California will begin smog checks, so I'd rather keep it stealth as much as possible.
zrt600guy
Jun 30, 2014 09:46 PM
Craig.Parks
Apr 12, 2013 04:23 PM
MC5C
Mar 23, 2013 12:34 PM
cyclone3565
Feb 1, 2010 01:27 PM
32MTXSHO
Nov 10, 2004 01:05 AM
