Got the Duraspark installed in my 70 and it runs great. I didnt get to drive it last night due to so many beer cans layin around! Is there a problem with having longer wires from the control module to the dizzy? I was trying to keep the install as clean and unoticable as possible so i ran the wires up along the drivers fender and behind the brake booster then up to the dizzy from behind the engine. It looks good but it did take about 5 feet of wire to get from the dizzy to the module.
I did the same thing. I put the module on the left inner fender an ran the wires up to the firewall an behind the engine to the dizzy. I did move the coil off the engine an mounted it to the firewall. So lengthening the wires is not a problem. The reason I did a duraspark conversion was the pertronix unit that I had used for about seven years failed . The replacement cost was to much for me $135 from O'reillys auto-parts
Good to hear, DSII will serve you well, MSD and all those other aftermarket "performance" ignitions are highly overrated, at least when it comes to a stock application.
Is there a problem with having longer wires from the control module to the dizzy? i ran the wires up along the drivers fender and behind the brake booster then up to the dizzy from behind the engine.
Not at all, that's the same as the factory wire routing on 73-79's.
Well I got out and drove it today and did some adjusting to the timing and now I am able to set the initial at 12 deg with 38 total! I wasnt able to get that with the points without lots of pinging. It does run smoother now and very smooth take off's. I'm glad I made the switch.
