Duraspark Ignition grounding
Old Jul 16, 2003 | 10:22 AM
Finnford's Avatar
Finnford
Does a Duraspark control module need to be grounded? Mine is attached to the plastic inner fender only. It was installed by previous owner and has been preforming ok.
Does seem to get hot after a while.
Old Jul 16, 2003 | 01:44 PM
Franklin2's Avatar
Franklin2
You should have three wires going from the module to the dist, orange, purple, and black. The black wire is the ground for the system. It grounds itself inside the dist.
Old Jul 16, 2003 | 02:32 PM
Torque1st's Avatar
Torque1st
Posting Legend
Mount the module with 1/4" spacers so air can circulate under the module for cooling.
