Wiring help..
Old Oct 15, 2011 | 07:54 PM
fifty-two_f1's Avatar
fifty-two_f1
Wiring help..
Okay, I have a 54 f600 that i have been tinkering with. It needs rewired. The mice had a hay day with the cloth... So I have a 55 wiring harness out of a fairlane station wagon. It has the plastic coating. This will save me a lot of money. Is there anything that I will have to add? I know the cars did not have starter buttons, but I can go around that. Other than that I think the car had everything that the trucks did instrument wise. Also I want to run relays for my headlights. Which ones should I get? Also how is my two speed rear end wired into the equation?
Old Oct 16, 2011 | 08:16 AM
GreatNorthWoods's Avatar
GreatNorthWoods
It should work with a little patience but it would be money well spent to get a new harness. That harness is over 50 years old so it may not be in the greatest of shape. I put a an 87 Chrysler harness into my 48 F-3 and spent about a week sorting out wires before I got it in. It worked out okay but it wasn't worth all the time I put in it. If you take your time you can do it.
Don't let the smoke out!
Old Oct 16, 2011 | 09:13 AM
ALBUQ F-1's Avatar
ALBUQ F-1
What do you do if the 57 harness wires are 3" too short on a circuit? Lots of cut'n'splices potentially. You could add the needed amount in the middle of the circuit. I'm sympathetic, wire prices are way up. It would be nice to have all factory terminals, for sure.
Old Oct 16, 2011 | 12:53 PM
POS-F500's Avatar
POS-F500
I just recieved the EZ wire kit. It was a miniature fuse block (great for limited space under-dash) and 20 circuit IIRC for $160... hard to beat that.
tubtub9677
May 18, 2015 09:32 AM
Dbass1292
Sep 14, 2014 06:07 PM
bamafarmboy
Mar 17, 2012 06:34 PM
SuperBeaner
Jun 7, 2010 11:04 PM
matt1morton
Feb 9, 2005 11:34 AM
