distibutor help
Old Oct 15, 2011 | 04:14 PM
beasty73ford's Avatar
beasty73ford
distibutor help
background: 351 C. got a HEI dist. from summit racing. set engine at 10 before tdc. firing order is correct. when i try to start it sometimes backfires and sometimes not. Ive tried everything i can think of. any have suggestions or advice would be awesome.
Old Oct 16, 2011 | 02:11 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Timing sounds off. If you have a no start condition(just backfire), I would suspect you set the dizzy in on exhaust stroke instead of compression stroke at TDC.
Old Oct 20, 2011 | 01:28 PM
beartracks's Avatar
beartracks
Make sure you are feeding the dizzy a full 12v. Don't use an ignition resister. You need a coil to match if you don't already.
76f350spercamprspeal
13
Aug 7, 2012 09:41 AM
montgomery7
23
Mar 1, 2010 07:53 PM
montgomery7
Feb 25, 2010 09:23 PM
rtcalabrojr
Sep 29, 2003 11:37 AM
flatliner
Jun 26, 2002 09:13 PM
