Engine temp warning light - false?
Old Oct 15, 2011 | 03:17 PM
tomph's Avatar
tomph
I was tooling around town testing my TQ lock-up proplem when I noticed the "engine temp" warning light (next to the "wait") came on. I looked at the temp stock idiot temp gauge and it was right where it normally sits about 1/4 swing from the left side of gauge.
I also noted that the "engine temp" light was not always bright and changed intensity with rpm. Sometimes it would get reeal fim and then it would go out and then come back on. Temp gauge is rock solid. I went on home and pulled my heat gun. Took readings at the top of radiator and it was about 185 degrees. No evidence of actual overheating.
I suspect the light is wrong and temps are fine. So - what turns on the engine temp lamp? Another one of those gremlins to brighten my day.
Thoughts or suggestions please.
Old Oct 15, 2011 | 03:25 PM
Lazy K's Avatar
Lazy K
The temp light unit is on the front of the drivers side head beside the valve cover with a single wire to it. Check that the wire and connector are good but possibly a bad sender unit.
Old Oct 15, 2011 | 03:38 PM
tomph's Avatar
tomph
the temp light has it's own sender different from the gauge sender?
Old Oct 15, 2011 | 03:40 PM
Lazy K's Avatar
Lazy K
Yes it does.
Old Oct 16, 2011 | 12:01 AM
joshofalltrades's Avatar
joshofalltrades
i've seen those sensors fail before. i used to have an LTD with one idiot light for temp and oil, started doing like yours, installed mechanical gages and left it unplugged. in hindsight, having the idiot light plus gage is a GREAT combination
get a new sensor and you'll be good
Old Oct 16, 2011 | 01:27 AM
Aune163rd's Avatar
Aune163rd
I think its the same issue as my brake light....i just ignore it, it comes and goes, mostly its on....
Old Oct 16, 2011 | 02:12 PM
tomph's Avatar
tomph
Took awhile to find it. Didn't see it until I removed the air intake hose. Cleaned and greased it - new one on order - quess we'll see from there. Like the idea of a real gauge and idiot light. Running out of gauge room. lol
stonemaster
Feb 19, 2015 09:13 PM
TheBigGreenMachine
Mar 22, 2010 10:51 PM
Todd Dietz
Jan 30, 2006 10:29 AM
f-250boy
Dec 15, 2003 12:15 AM
Stinger_916
Oct 7, 2003 05:34 AM
