Help needed! New/used intake
Old Oct 14, 2011 | 01:10 PM
73f250highboy's Avatar
73f250highboy
Hello i have recentally bought a new to me used aluminum intake and the bypass tube nipple is missing . Its the one that goes to the water pump. I believe it is a press in fitting? The hole doesnt seem to be threaded. ANy help on how to fix this problem would be very appreciated. I would like to be start the motor up this weekend. TIA
Old Oct 14, 2011 | 08:23 PM
mark a.'s Avatar
mark a.
I got one from Summit.
Old Oct 14, 2011 | 09:08 PM
73f250highboy
I did some more research and i just decided to tap it to 3/8 npt. will be picking up the fitting tomorrow. Still wont be able to start the truck though need to get the flywheel balanced...
Old Oct 15, 2011 | 10:35 PM
mark a.'s Avatar
mark a.
What do you mean by "get the flywheel balanced " ? If your big block is internal balanced then the flywheel doesn't get balanced. If it's external balanced then the flywheel is balanced with the crank as a unit.
Old Oct 15, 2011 | 10:43 PM
73f250highboy
Its an internal balance motor and im swapping in a zf transmission and i want to us the 460 flywheel i got with it so it has to be zero balanced.
junkyarddog82
Feb 12, 2008 09:53 PM
Unfairlane62
Feb 27, 2006 11:19 AM
Power_age
Dec 14, 2004 02:31 PM
FatzFord
16
Feb 27, 2004 09:04 AM
