Replace your tires
Old Oct 14, 2011 | 11:22 AM
timmyboy76's Avatar
timmyboy76
Replace your tires
i uh, procrastinated, and now paying the price. Few months back, somehow developed a "hole" on the sidewall, well put a plug in it and been fine since. JUST the other day, i rotated my tires, and noticed the pass/front was bad, should've been replaced, but flipped it to the back, thinking the tread will even out. Since then, it had a "wobble/bounce" to it, but convinced myself it was the one with the plug, since at the time of rotating, i pumped in the "slime" stuff to hewlp patch things up. SO, other night, i removed the patched tire, and installed my spare...next morning taking daughter to school, noticed it still "bounced", and now thought, great, grabbed the wrong tire to swap out. Got her to school, and on way back doing 70-ish...BAM, tire blew out, and not only that, took out my pass/rear quarter-panel....yup, i'm bummed.
Old Oct 14, 2011 | 11:51 AM
riverrat41's Avatar
riverrat41
I am very **** about tires.I do not wear out tires.I will buy a new SET when the tread has about 1/4'' 3/8'' left.I have seen several fender wells torn apart from the very same thing that happened to you.If it would have been on the front at 70mgh you might have had a rodeo on your hands.Not worth it to me.
Old Oct 14, 2011 | 11:54 AM
7.3 Rocket's Avatar
7.3 Rocket
Sounds like a belt slipped around in there. They typically do that as a set. If one goes in that manner the others are soon to follow. If you notice a strange vibration check your tires for unusual bumps. If you find one replace the set.
timmyboy76's Avatar
timmyboy76
Yup, that why the rotation. Thing is, the wear was on the inside, so figured it would then wear even...wasnt the outcome. I could not have imagined, what it been like, for it to go, installed on front, it was a mess when it let go...in a slight dog-leg turn..etc, dont wanna replay this scenerio again...
Old Oct 14, 2011 | 11:58 AM
riverrat41's Avatar
riverrat41
Glad it just got the fender well and you were o.k.We all live and learn in many different ways and instances.
Old Oct 14, 2011 | 11:59 AM
timmyboy76's Avatar
timmyboy76
Yeah, what sucks is that, i got the money, but just didnt pull the trigger. Now i HAVE TO pull the trigger along with atleast a 500-1k bill for repairs...doesnt add up. Just a bummer, truck, when clean looks good, and gets the job done, now, i got this da$# damage...
Old Oct 14, 2011 | 12:01 PM
7.3 Rocket's Avatar
7.3 Rocket
Gamble and win for long enough you're bound to lose eventually. I know I've had my fair share of losses.
Old Oct 14, 2011 | 01:37 PM
nlemerise's Avatar
nlemerise
Two things NOT to wait on, BRAKES & TIRES...In commercial vehicles they will hang you if defect found, and rightfully so.
Old Oct 14, 2011 | 01:48 PM
timmyboy76's Avatar
timmyboy76
O YEAH...run'n mixer trucks, did our walk around every morning, before firing up/leaving the plant.
I'm just glad it didnt "go" when taking daughter to school....What was weird was the "wobble/bouce" after the slime was installed. I chalked it up to IT, causing the imbalnce.
Old Oct 14, 2011 | 08:35 PM
PaysonPSD's Avatar
PaysonPSD
Another thing not to do is put a plug in the sidewall. Any reputable tire shop would never do that so you shouldn't do it either. The plugged tire was the one that blew out wasn't it.
Malixous
Jun 14, 2013 08:02 AM
havdaddy
Aug 4, 2010 11:16 AM
pgonza2723
Jul 1, 2009 11:28 PM
Talyn
28
Jul 10, 2004 10:06 AM
MRBASS
Nov 1, 2003 06:34 PM
