Help matching gear ratio
Subscribe
Oct 15, 2011 | 06:36 AM
Quote: The ID tag is WDM-CJ 9CB 275 9 356A
So, I know this - it's a 2.75 gear ratio, 28 spline.
WDM-CJ = Ford 9" Rear Axle / 2.75-1 / non Limited Slip / Parts List #91.
9CB = Assembled the second week (B) of March (C), 1979 (9).
356A: 356 = Assembly Plant code / A = First design.
D6TZ-4234-C .. R/L 28 Spline Axleshaft-32 7/64" long / Use with 1/2" backing plate bolts.
D8TZ-4234-E .. R/L 28 Spline Axleshaft-31 27/32" long / Use with 3/8" backing plate bolts.
1979: FoMoCo used two different sizes of backing plate bolts.
FoMoCo Parts Catalogs measure axleshafts from the inside of the flange .. to the splined end.
Source: 1973/79 Ford Light Truck Parts Catalog / Text, Section 40.1, Pages 8-10 ~ Rear Axle Parts List #91 // Text, Section 41, Pages 6 & 7 ~ Axleshaft Size ID Chart.
Reply 0
Oct 17, 2011 | 10:09 AM
Where would i find either of these numbers? D8TZ-4234-E, D6TZ-4234-C
Count splines! CHECK !
Anyone know a really good 9 inch rear rebuild? This is my first dive into a rebuild like this and Im going to need good step by steps..
Also, At the end of the axle where i believe the wheel bearings rub against the axle there is what appears to be a metal sleeve/ring. Should this sleeve/ring move? what is this called ?
Reply 0
Oct 17, 2011 | 10:15 AM
Quote: Where would i find either of these numbers? D8TZ-4234-E, D6TZ-4234-C
I was looking at this one.. But its not dummied down as much as i need it to be.. PICTURES.. I NEED PICTURES :-) - Ford 9 Inch Rebuild/Gear Setup .: Articles
Reply 0
Oct 17, 2011 | 01:39 PM
Removed comment - by me
Reply 0
Subscribe
