Help a rookie plz
Old Jan 30, 2008 | 09:22 PM
Raider50's Avatar
Raider50
Help a rookie plz
Im kinda you i suppose and am still learning and need some help im looking at a 79' f150 that needs a new drivetrain ive seen and heard about dana 40, 44, or 60 i think what has the lowest gear ratio?
Old Jan 31, 2008 | 12:37 AM
tylstruck's Avatar
tylstruck
You're all over the place with that statement/question. Truck must be a 4x4 to have Dana axle s.
Would be helpful to know the size of engine, and trans? manual or auto?
Tyl
Old Jan 31, 2008 | 06:29 AM
cujo8's Avatar
cujo8
Dana 40, 44, 60 are the axle model numbers and the actual gear ratio is independent of model #. The gear ratio is the calculated by the # of teeth on the ring gear divided by the # of teeth on the pinion gear. For example you could have a three different model Dana axles and they all could have the same gear ratio in them, but the gears can be changed in any axle to achieve the ratio you want.
Old Jan 31, 2008 | 06:23 PM
Raider50's Avatar
Raider50
Ok, its a 79' 460 stick 4x4, so the revised question i suppose is what axels would it have? and how would i go about changing the gear ratio if it dosnt have the one that i want/need?
Old Jan 31, 2008 | 07:11 PM
Mil1ion's Avatar
Mil1ion
Dana's were put in F250's and larger
F150's usually got Ford 9" axles.
That truck has been made up being a 4x4 with 460 and M/T
You need to get the tag info off the diff cases
Btw, Please title threads with the actual topic so we know what the thread is actually about
Here are the 1979 axle options for all Light trucks.
Splash67
Oct 9, 2013 03:18 PM
Abester89
Sep 22, 2011 10:11 PM
stevilknevil
New Member Introductions
Apr 6, 2008 11:21 AM
steven c
Flathead V8 & Flathead 6
Feb 10, 2007 10:28 AM
John1201
Aug 5, 2001 11:34 AM
