engine quit
Old Oct 13, 2011 | 08:19 PM
amadas350's Avatar
amadas350
Exclamation engine quit
pulled into gas station with truck running great, and after filling it up truck would turn over but not start. finally pulled it off, and ran great.
few hours later, going down road fine, let off pedal to slow down and truck shut off. started to open the cap on fuel filter and fuel started to shoot out like it was under alot of pressure.
any ideas. i would try to look some more info up, but net running extremely slow.
2001 f550 7.3
Old Oct 13, 2011 | 08:22 PM
riverrat41's Avatar
riverrat41
Sounds like you need to change out the CPS.Cam position sensor
Old Oct 13, 2011 | 09:18 PM
BigAlsPSD's Avatar
BigAlsPSD
Being a 550 they have a liner inside the tank I believe, it could be possibly that it is clogging your tank vent building pressure I suppose. The pressure at the filter seems unique though, with that pressure it's probably fine. Start with the CPS, one of the first easy things to swap if your truck is dying.
Old Oct 14, 2011 | 08:07 AM
Tailgate77478's Avatar
Tailgate77478
CPS...and if you haven't had the Ford Recall done for the CPS yet, just go into the dealership and get it done for free. Otherwise, they're like $20 and 15 minutes of your time.
Swat_Medic
May 13, 2018 02:20 PM
Joe28443
Dec 8, 2015 08:10 PM
timothy l
May 18, 2013 07:16 PM
bass-n-fire
31
Oct 8, 2012 08:11 PM
gordeaux
15
Jun 17, 2007 08:06 PM
