7.3 misses at highway driving
My 2002 super duty 7.3 runs fine but acts like it misses while driving at highway speeds but will continue to run after the miss and every once in a while will shut off while stoped at a light. It will start immediately after it shuts down. Could this be the fuel supply pump? Looking for advise.
timothy l
timothy l
timothy l
timothy l
It could be fuel pressure, but it could be a lot of other things.
To rule out fuel pressure, you need to install a fuel pressure gauge and check it WHILE DRIVING. A simple pressure at idle will not reveal any partial blockages in the fuel system.
Its a pretty easy thing to check, so start with that.
It could also be a CPS failure. There is no test for this, just to replace it. Fortunately they are cheap. Be sure to only use an OEM CPS from Ford. You may also want to check IPR and ICP values, but you will need a high end scanner for this.
