Over fueling
Old Oct 14, 2011 | 11:49 PM
mikeyc0120's Avatar
mikeyc0120
Correct me if I'm wrong but isn't white smoke due to a LACK of fuel, not too much? When you floor the throttle or add performance tunes, it will over fuel and you get black smoke. Same with a fire, add fuel = black smoke, take away fuel (ie smoldering or put water on it) = white smoke.
Now, my truck has spit white smoke a few times and each time was ultimately due to a lack of fuel. Fuel line O rings on the side of the fuel bowl were leaking not giving it enough fuel and when I first got the truck and didn't know much about diesels, had the oil run low and truck would stall from not running the injectors fully.
I would check those two, check your fuel pressure could be failing pump or clogged regulator.
Old Oct 15, 2011 | 12:05 AM
PaysonPSD's Avatar
PaysonPSD
Originally Posted by Krazymaan
Oh yea, your right. Single shots require a tune in an 01.
Its been a long day building someone else's dream. ( i'm a contractor )
Building someone else's dream to live or try to live your own dream.
Old Oct 15, 2011 | 12:52 AM
PaysonPSD's Avatar
PaysonPSD
Too much fuel going into the cylinder will not ignite under compression. That fuel will be expelled on the exhaust stroke as a mist that looks like white smoke. The exhaust for that cylinder will be cooler becuse the fuel did not ignite. That's why it's a good idea to use an IR temp gun to find a bad injector.
The black smoke is fuel that is not fully ignited or in other words not completely burned. As the rpms go up and the turbo spools adding more air, and in practicality a higher compression ratio, much higher heat is produced during compression and that same amount of fuel, or even a much greater amount, burns clean and the black smoke clears.
Like you pointed out add water white smoke - but because the fuel won't burn. It's not due too little fuel. The water will displace oxygen the fuel needs to burn.
Add fuel black smoke - but because all the fuel deesn't burn clean. You drop more fuel on and there is not enough initial heat to burn completely and it will also displace enough oxygen initially to cause a dirty burn.
Old Oct 15, 2011 | 01:20 AM
mikeyc0120's Avatar
mikeyc0120
Ahhh, always learning something! lol thanks
Old Oct 15, 2011 | 01:25 AM
PaysonPSD's Avatar
PaysonPSD
I'm always learning too. That's why I'm here.
Meydawg51
Jul 31, 2015 09:57 AM
1994F2507.3L
Oct 11, 2014 08:09 AM
jfaber
Nov 14, 2009 10:34 AM
4drf350
23
Aug 30, 2007 10:47 AM
4601ton
3.0L V6
Aug 30, 2006 07:00 AM
