blown fuse ??
Old Oct 11, 2011 | 09:22 PM
ConvertedFord's Avatar
ConvertedFord
blown fuse ??
I was removing the inside light when the screw touched the bulb and sparked. After that my radio wont come on and the reading lights wont come on. also my windows wont let down. All other lights work correctly including the inside lights but not the manual reading lights. I've checked fuses and they all seem good. Any Help??? thanks
Old Oct 11, 2011 | 10:34 PM
dchamberlain's Avatar
dchamberlain
Check the Delayed Accessory fuse, #42 under the steering column.
Test fuses with a test light or a meter. A fuse can appear OK but still be blown.
Old Oct 12, 2011 | 06:30 AM
ConvertedFord
well it wasnt 42. I checked every fuse that could be related with a ohm meter. the only one im not sure of is 306 which is a 4 pin relay.
Old Oct 12, 2011 | 09:17 AM
dchamberlain
All of the items you mentioned are powered through the accessory delay circuit. This is a fused circuit (42) and controlled by the Accessory Delay Relay (#306). It is possible that what you did damaged that relay, even though the fuse should have protected it.
There should be a diagram on the side of that relay showing which 2 pins are the coil and which two are the contacts. If you take it out and put power and ground on the coil, you should be able to measure continuity across the contacts.
Old Oct 12, 2011 | 09:56 AM
DSMMH's Avatar
DSMMH
Just swap the # 306 relay with another similar relay. There are plenty of them in the fuse/relay panel.
DSMMH
iwritesql
Electrical Systems/Wiring
May 13, 2010 09:02 PM
tbaker00
Oregon Chapter
Jun 17, 2009 11:32 PM
tomtoc
Aug 12, 2007 03:15 AM
MiKeYs 2k DiEsEl 4x4
Aug 1, 2007 06:41 AM
yamaguy
Jul 22, 2007 11:02 PM
