6.0L no start need Help!
Old Oct 16, 2011 | 01:56 PM
knsahara's Avatar
knsahara
Let me ask you guys this then, I did the voltage reading at the ipc while cranking and was getting nothing on the meter. What are your thoughts on that?
Old Oct 16, 2011 | 01:59 PM
NewToDiesels's Avatar
NewToDiesels
If your checking it correctly, it more than likely means your IPR valve is clogged as cheezit said earlier. You need .8 volts to start.
cheezit's Avatar
cheezit
either you did in incorrectly or you are not getting high pressure oil. however you should have between .14-.24v key on engine off.
so being that the ipr is the output and icpv is the input it goes back to to the output being the issue.
Old Oct 16, 2011 | 08:35 PM
knsahara's Avatar
knsahara
Im going to bite the bulle and replace the ipr. Should I just get it from the dealer or order frow somewhere else that you would recommend.
Old Oct 16, 2011 | 10:01 PM
NewToDiesels
Order from Minneapolis Ford Dealer - Tousley Ford - New & Used Ford Cars, Trucks, SUVs & Hybrids - Minneapolis Minnesota Dealership - Serving Saint Paul, Stillwater, Hudson, Hastings, White Bear Lake, Anoka or www.partsguyed.com They are the cheapest source for OEM parts. If you have an International dealer nearby, they would probably be cheaper than any Ford dealer.
International PN 1833798C91
Ford CM-5126
You'll want to double check these. IPRs are different for different years. Not 100% on the International PN - not sure if it's for the right year.
Horizon Ford (Parts Guy Ed) link to the part is www.partsguyed.com
Old Oct 16, 2011 | 10:18 PM
bismic's Avatar
bismic
TousleyFordParts or PartsguyEd are the two best places to go for parts IMO.
2006 IPR:
5C3Z-9C968-CA
1846057C1
Old Oct 19, 2011 | 07:58 AM
knsahara's Avatar
knsahara
I got t give credit were credit is due. Cheezeit you were right! I replaced the ipr and she fired right up. Thanks so much for your knowledge and wisdom God bless you !
Old Oct 19, 2011 | 09:18 AM
NewToDiesels
He's a Master. Kind of like Master Yoda.
Old Oct 19, 2011 | 05:30 PM
cheezit's Avatar
cheezit
anytime. .
kujo3692
Sep 9, 2017 10:31 AM
Freskan6.0
Feb 3, 2017 02:09 PM
jsimon724
May 18, 2012 07:28 PM
bootlakeman
Sep 11, 2011 04:41 PM
hndacr
Dec 21, 2009 06:14 PM
