Sponsored by: Auxito
4.2 v6 engine swap
Old Oct 11, 2011 | 12:35 PM
fairchild25's Avatar
fairchild25
Question 4.2 v6 engine swap
i got a 99 f150 with a 4.2. i was wondering what a good engine to drop in it would be. looking at the triton v8. what do yall think?
Old Oct 11, 2011 | 09:32 PM
Bluegrass 7's Avatar
Bluegrass 7
Here are 'some' items for you to think about.
The PCM has to be changed.
The harness from a V6 to a v8 for differences in engine control hardware.
Exhaust CATS and any differences in muffler hook up.
Cooling system changes etc.
If you have a doner truck with all the items it makes it a lot easier.
Better to get a V8 to start with and elminate all the hassles because you have a learning curve along with back yard engineering at the same time, to get over.
Good luck.
Old Oct 13, 2011 | 05:19 PM
fairchild25
im only 18 but my dad has had the truck since i was like 6 or 7, the truck means alot to me so replacing the truck isnt an option but thanks for the reply
Old Oct 13, 2011 | 05:58 PM
Bluegrass 7
I had no way to tell what the value of the truck is to you, from your first post..
The point being offered is; do you understand that it is not a drop in swap?
Without knowing what your position is, the general answer is still the same unless you want to take it on as a long term project with lots of learning along the way.
Would be easier to replace the motor with a rebuilt unless there is nothing wrong with the one you have.
Good luck.
Old Oct 17, 2011 | 11:38 PM
fairchild25
its all good i understand and once again thanks for the help
jimmerf79
1997 - 2003 F150
Sep 20, 2019 01:58 PM
kurtackerman
1997 - 2003 F150
Jul 6, 2010 02:06 AM
Joe Grizzly
1997 - 2003 F150
Apr 8, 2008 07:19 PM
blueovalman2
1997 - 2003 F150
Jul 4, 2005 09:36 AM
JohnnyTapia
1997 - 2003 F150
Aug 13, 2004 09:29 AM
