need help
Old Oct 10, 2011 | 06:54 PM
gjnicholas's Avatar
gjnicholas
need help
the truck has a bad miss once it warms up at idle and is noiser than normal. how would I find the bad injector no codes have shown up.
help
and thanks
Old Oct 10, 2011 | 06:56 PM
Crash16's Avatar
Crash16
Sounds more like an ICP sensor or the Ipr valve.
Old Oct 10, 2011 | 06:57 PM
npccpartsman's Avatar
npccpartsman
Check your FICM voltage and if you're using the SG2 to scan your 04 for codes get something else.
Old Oct 10, 2011 | 07:54 PM
gjnicholas's Avatar
gjnicholas
ficm voltage is 48 steady and yes using the sg to pull codes i have a sct tuner will that work better
Old Oct 10, 2011 | 08:01 PM
npccpartsman
Maybe but I doubt it.
Old Oct 10, 2011 | 08:27 PM
BLADE35's Avatar
BLADE35
if you dont get a code either a dealer or an Auto Enginuty for a cylinder balance test
Might also try to give the injector harnesss a wiggle test might have a short
So at cold startup it runs smooth as silk?????
Old Oct 11, 2011 | 05:48 AM
gjnicholas's Avatar
gjnicholas
yep at cold start it funs smooth if you let it idle for about 5 to 10 minutes it will start to miss ramdomly but not real bad the longer you let it idle the worse it will miss. i started it last night and found that out. yesterday when i left to go to work it cranked normal i left and got about a mile down the road to a stop light and thats when it started acting up drove it home and thats where it sits.is there anything i can look at with the scan gauge to tell me if an injector is going south? i also looked at ICP and IPR the values looked normal for what they been running.
thanks again
Old Oct 11, 2011 | 09:51 AM
Rusty Axlerod's Avatar
Rusty Axlerod
Here's some codes for fuel injectors in X Gauge. I haven't used them myself, but might be worth a shot:
These are from James DeLong at Scangauge. (Well, thats a lot of gauges. )
Yea, MAP is a standard gauge - but this XGauge is actually better than the standard one. It has a larger range which was needed because the standard gauge tops out around 37 psi absolute (about 22 lbs of boost), which diesels have no problem doing. This one should read well beyond 22lbs of boost.
Manifold Absolute Pressure
TXD: 07E0221440
RXF: 046285140640
RXD: 3010
MTH: 012203200000
NAM: PSI
With a little tweaking you can adjust this to read boost as you said.
To do this, just plug in the MAP code - get a reading from it with the key in the on position but the engine off, then based on the reading changed the last 4 digits of the MTH to whatever corresponds to your reading on this table
14.0 -- FF74
14.1 -- FF73
14.2 -- FF72
14.3 -- FF71
14.4 -- FF70
14.5 -- FF6F
14.6 -- FF6E
14.7 -- FF6D
14.8 -- FF6C
14.9 -- FF6B
15.0 -- FF6A
So, for example if you got a reading of 14.5 PSI with key on engine off you'd change the MTH to 01220320FF6F and the reading should read 0.0 with key on engine off and would then show how many lbs of boost you were at when the vehicle is running.
Quote:
Originally Posted by DieselStroke
Go ahead and give me any codes that you may have for the injectors, i am always happy to try out new things. Please let me know if you have any other gauges for our trucks that may be potentially useful, we are happy to try anything you throw at us.
Thanks,
Patrick
Here's what I have for injectors
Injector Timing Before Top Dead Center (Degrees)
TXD: 07E02209CC
RXF: 0462850906CC
RXD: 3010
MTH: 000A00400000
NAM: ITM
Fuel Injector Pulse Width (microseconds)
TXD: 07E0221410
RXF: 046205140610
RXD: 3010
MTH: 000800010000
NAM: FPW
Fuel Injector #1 Commanded on (On/0ff)
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3001
MTH: 000100010000
NAM: FI1
Fuel Injector #2 Commanded on (On/0ff)
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3101
MTH: 000100010000
NAM: FI2
Fuel Injector #3 Commanded on (On/0ff)
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3201
MTH: 000100010000
NAM: FI3
Fuel Injector #4 Commanded on (On/0ff)
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3301
MTH: 000100010000
NAM: FI4
Fuel Injector #5 Commanded on (On/0ff)
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3401
MTH: 000100010000
NAM: FI5
Fuel Injector #6 Commanded on (On/0ff)
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3501
MTH: 000100010000
NAM: FI6
Fuel Injector #7 Commanded on (On/0ff)
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3601
MTH: 000100010000
NAM: FI7
Fuel Injector #8 Commanded on (On/0ff)
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3701
MTH: 000100010000
NAM: FI8
He is working on an injector misfire count right now that should tell us if there is an injector that is performing worse than the average!
Here's what I have for misfire counts.
Cylinder #1 cumulative misfires
TXD: 07E022160E
RXF: 04620516060E
RXD: 3010
MTH: 000100010000
NAM: 1CM
Cylinder #2 cumulative misfires
TXD: 07E022160F
RXF: 04620516060F
RXD: 3010
MTH: 000100010000
NAM: 2CM
Cylinder #3 cumulative misfires
TXD: 07E0221610
RXF: 046205160610
RXD: 3010
MTH: 000100010000
NAM: 3CM
Cylinder #4 cumulative misfires
TXD: 07E0221611
RXF: 046205160611
RXD: 3010
MTH: 000100010000
NAM: 4CM
Cylinder #5 cumulative misfires
TXD: 07E0221612
RXF: 046205160612
RXD: 3010
MTH: 000100010000
NAM: 5CM
Cylinder #6 cumulative misfires
TXD: 07E0221613
RXF: 046205160613
RXD: 3010
MTH: 000100010000
NAM: 6CM
Cylinder #7 cumulative misfires
TXD: 07E0221614
RXF: 046205160614
RXD: 3010
MTH: 000100010000
NAM: 7CM
Cylinder #8 cumulative misfires
TXD: 07E0221615
RXF: 046205160615
RXD: 3010
MTH: 000100010000
NAM: 8CM
If you get good info on the misfire count codes let us know. Would be a good tool to have. Good luck!
Old Oct 11, 2011 | 01:44 PM
npccpartsman
I never had any luck with most of the injector xgauges. I'm starting to think it's exhaust leaking into the fuel rail but there are too many other things it could be as well.
Old Oct 11, 2011 | 06:51 PM
gjnicholas's Avatar
gjnicholas
how would i figure where exaust would be leaking in at. will a shop computer pick that up or any thing i can do to find out
Old Oct 11, 2011 | 07:25 PM
BLADE35's Avatar
BLADE35
You need to do a ballon test to narrow it down to which head
then after you figure what head it is let it warm up till its missing again the unplug each injector 1 at a time when you unplug the bad one there will be NO Change in how it runs when you unplug the good ones it will sound and run Worse and miss harder
a cylinder balance test may get it too IDK
Old Oct 12, 2011 | 07:49 PM
gjnicholas's Avatar
gjnicholas
looked at truck tonight
cranked and let it warm up the miss was inter-minting but after i wiggled all the wires and pulled the injectors it quit missing pulled all the injector plugs and could not tell which injector was giving the trouble
going to wait till friday and see what i can figure out
Old Oct 12, 2011 | 09:41 PM
BLADE35's Avatar
BLADE35
Almost sounds like a bad injector harness
wire harness chaff locations
<TABLE style="WIDTH: 568pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=757><COLGROUP><COL style="WIDTH: 568pt; mso-width-source: userset; mso-width-alt: 27684" width=757><TBODY><TR style="HEIGHT: 76.5pt" height=102><TD style="BORDER-BOTTOM: #f0f0f0; BORDER-LEFT: #f0f0f0; BACKGROUND-COLOR: transparent; WIDTH: 568pt; HEIGHT: 76.5pt; BORDER-TOP: #f0f0f0; BORDER-RIGHT: #f0f0f0" class=xl65 height=102 width=757>Wiring Harness Chafing:
Some trucks with the 6.0 may exhibit a crank/no start, rough running, misfire, buck/jerk or lack of power. This may be due to the FICM harness chafing on a valve cover stud near the FICM. Other potential locations for chafing are where the harness routes past the EBP sensor, the belt idler on the driver side of the engine, the glow plug control module bracket on the passenger side of the engine, and the accelerator pedal sensor wires at the steering column (adjustable pedals only). Reroute and repair the harness as necessary. Broadcast Message 0918/1374, SSM #17522.
</TD></TR></TBODY></TABLE>
Old Oct 13, 2011 | 06:11 AM
gjnicholas's Avatar
gjnicholas
thanks I'll take a close look at all those locations
Piston6
Oct 7, 2013 12:32 PM
countrykid_86
Nov 7, 2009 05:15 PM
tinker934
Feb 20, 2009 04:03 PM
btsb032304
Jul 24, 2008 09:36 AM
fordracerman
Sep 23, 2005 10:25 PM
