Reverse problems...
Old Oct 10, 2011 | 03:02 PM
Dusrusg's Avatar
Dusrusg
Reverse problems...
My daily driver is an '86 F-150 that was originally a 302 manual trans. Somewhere along the line, she got a transplant of an older (carbureted) 302 and a c6. I thought I read somewhere in the archives that some rear-end gearing is too steep for the c6's reverse gear... I crawled under the truck and inspected my rear, looking for the id tag, and found nothing. I do know it's an 8.8", and I have no reason to believe it's original, since the rest of the drivetrain isn't...
Here's the problem: when changing the fluid/filter a few months ago, I found part of a clutch disc in the pan. The fluid/filter (and a modulator) really firmed up the shifts, and it ran great, for a while. Now, I've nearly lost reverse!
The options, as I see them, are:
1. rebuild the c6 and just run it
2. rebuild the c6 and swap a differently geared rear
3. find a donor and swap back to a manual
Suggestions? Cautions? Help?
Old Oct 10, 2011 | 04:34 PM
Sw1tchfoot's Avatar
Sw1tchfoot
Rebuild the C6 and just run it, unless you want a manual transmission or if you are not satisfied with the current rear end gears.
Old Oct 10, 2011 | 07:18 PM
Franklin2's Avatar
Franklin2
I have never heard of incorrect gearing damaging the c6?
Dads79
Sep 17, 2017 05:32 PM
daubie
May 25, 2011 12:40 PM
Ken Blythen
May 1, 2011 09:44 PM
edsf100
Jan 25, 2011 07:58 AM
FS88Bronco
Oct 4, 2002 12:06 PM
