Sponsored by: Real Truck
air bag dummy light
Old Oct 10, 2011 | 01:27 PM
SBastow's Avatar
SBastow
air bag dummy light
light flashing then stays on constant. The bulb illuminating "off" is also not working. Could this light be on because the bulb burned out?
Old Oct 10, 2011 | 06:58 PM
projectSHO89's Avatar
projectSHO89
Count the flashes to read the two digit flash code. If it's 27, then the fault is due to the bad bulb on the PAD switch.
Old Oct 11, 2011 | 09:05 AM
SBastow's Avatar
SBastow
It is 27. How do I get at the bulb to replace?
Old Oct 12, 2011 | 11:38 AM
SBastow's Avatar
SBastow
Any help here? This light on is driving me crazy!
Old Oct 12, 2011 | 11:45 AM
husker's Avatar
husker
I had the bulb burn out a couple of years ago and went to radio shack and bought a new LED with a resistor. Pulled the old one from the circuit pad and soldered in the new one. It has been fine since. You have to pull the radio etc. to get the circuit out. There should be a thread on this here somewhere. I don't remember all the directions or the size of LED needed. Hopefully someone else will chime in.
Old Oct 12, 2011 | 12:52 PM
SBastow's Avatar
SBastow
WTF? What kind of design is this? It's just a light to tell you the airbag is off!
jrf250
May 28, 2014 06:56 PM
00GT
1983 - 2012 Ranger & B-Series
May 11, 2011 10:46 AM
BigJake34452
13
Mar 25, 2009 09:28 AM
RonC80
Feb 27, 2009 09:35 AM
baslerxlt
1997 - 2003 F150
Dec 20, 2008 01:17 PM
