68 f250 shift collar?
D5TZ-7228-A (replaced C5TZ-7228-B & C9TZ-7228-A) .. A/T Shift Collar / 1965/77 F100/350.
MSRP: $65.98 / FTE sponsor PARTSGUYED.COM price: $47.51 / PartsGuyEd = Horizon Ford in Seattle (Tukwila) WA
The FORDification.com Forums • View topic - Turn Signal Switch Replacement - tutorial
Did this the first time some 35 years ago as a teenager replacing a 3-on-the-tree shift collar...my old man was rough on stuff. Wasn't any easier the second time...earlier this year, but the link helped...hardest part is getting the turn signal housing back on right when you are putting it back together...that and keeping the column from popping up. Have a helper handy...3 hands definitely required.
The tutorial truck is a 1969 = There are two different T/S switches.* One has loose individual wires, the other has wire connectors.
Loose wires: When each colored wire is removed from the connector, its location must be recorded, otherwise...if the new wires are installed in the wrong locations...you can kiss the new switch good-bye.
And a special tool is required to pull these wires from the connector.
There is a much easier way to R&R T/S switches w/loose wires that Ford techs used.
1) CUT the old switch wires off above the connector, leaving enough that their color codes can be determined.
Tape the wires together, tie a long piece of string to them.
2) REMOVE the switch from the column, tape the new switch wires together, tie the string to them.
3) PULL the string from the bottom of the column, the wires will feed easily down the column.
Now, remove each colored wire end from the connector, then replace with the each correct colored wire.
If this method isn't used, it can be a real b!tch feeding the new switches loose wires down the column, because they usually bunch up.
* There are two different T/S switches:
C9TZ-13341-C ~ Loose individual wires: 1965/66 F100/250 2WD / 1966 F100 4WD / 1967/68 F100/350 / 1969 F100/350 before serial number G30,001.
DOTZ-13341-B ~ Wire connectors: 1969 F100/350 from serial number G30,001 / 1970/72 F100/350.
I'm sure you're right on track with the rest of the info...where were you 35 years ago when I was young, stupid and stubborn and needed a mallet to the head to understand all this?
