fuel in water
Old Oct 9, 2011 | 04:25 PM
nolaguy's Avatar
nolaguy
fuel in water
My overflow smells of diesel. Now it started smoking white real bad. Whats the deal? What do I change ?
It's an "05 F350. I think this motor sucks. One problem after another. Mostly egr system.
Old Oct 9, 2011 | 04:26 PM
npccpartsman's Avatar
npccpartsman
EGR cooler gone bad or cracked head. Usually if your coolant is diesel contaminated it's a cracked head.
Old Oct 9, 2011 | 04:35 PM
nolaguy's Avatar
nolaguy
Thanks. That sucks. I hear egr bypass systems cost about a grand. I dont even want to think what a new head replacement will cost.
Old Oct 9, 2011 | 04:40 PM
npccpartsman
EGR deletes are about $150 plus install. A new head is a grand plus install. Do you smell exhaust in the coolant or is it fuel? BIG difference here.
Old Oct 9, 2011 | 04:44 PM
m-chan68's Avatar
m-chan68
3C3Z-6049-DA is the part number for a cylinder head kit that includes the cylinder head itself, the head gasket, new cylinder head bolts, as well as new standpipe. Price that part number from various Ford parts sources to give you an idea on the cost of the part.
Old Oct 9, 2011 | 05:00 PM
npccpartsman
$1000.96 from Tousley so I was just a little low......oh.....plus 250 core charge.
Old Oct 9, 2011 | 05:01 PM
nolaguy's Avatar
nolaguy
I smell fuel in the coolant. and it is black no matter how many times i flush it
Old Oct 9, 2011 | 05:38 PM
Unrealo4's Avatar
Unrealo4
If its black that sounds more like oil cooler failure. Not sure that's any cheaper of a fix. but if you continue to drive it that way you will be buying a new engine.
Old Oct 9, 2011 | 06:05 PM
npccpartsman
If it was an oil cooler failure it would look like a chocolate milkshake--thick and creamy.
Old Oct 9, 2011 | 09:48 PM
nolaguy's Avatar
nolaguy
I will put it in the shop tomorrow. I can't afford to have it down for too long. I'll post the results in case it happens to someone else.
Old Oct 9, 2011 | 10:44 PM
BLADE35's Avatar
BLADE35
If you have oil in coolant DO NOT DRIVE IT or even start it for that matter
hows the oil leval
does it look like this
Old Oct 9, 2011 | 10:55 PM
smokersteve's Avatar
smokersteve
Wow!^^^^^^^^
Old Oct 10, 2011 | 08:54 AM
BlueMonster33's Avatar
BlueMonster33
Oh my god is that for real?
Old Oct 10, 2011 | 12:01 PM
BLADE35's Avatar
BLADE35
Unfortunatly it was for real
heres the thread I got the picout of
https://www.ford-trucks.com/forums/1...l#post10770470
The Bad part of this kinda Failure is it takes the moter out quick when they see it get hot for the first time its already to late
Old Oct 10, 2011 | 06:04 PM
cheezit's Avatar
cheezit
I should have one of those in my stall here soon to fix
91dirtydiesel
Dec 5, 2012 09:17 AM
RainHellFromAbove
Jun 8, 2012 09:49 PM
Teds
Nov 20, 2011 01:32 AM
ibrown
Apr 5, 2011 02:03 PM
05rattler
Jan 10, 2010 08:16 PM
