power valves again!
Old Nov 2, 2011 | 10:20 AM
  #31
lavatan's Avatar
lavatan
Originally Posted by ctubutis
Why would one want to coat a paper gasket with anti-seize?
I could see someone using RTV sparingly to seal it better, but anti-seize would just make the gasket unusable I would think.
Old Nov 2, 2011 | 10:29 AM
  #32
ctubutis's Avatar
ctubutis
Huh... I've never in my life used any kind of sealant or substance on any of those gaskets, nor have I ever wished I had.
Old Nov 2, 2011 | 10:37 AM
  #33
lavatan's Avatar
lavatan
I haven't either, but if someone were to use a sealant, I wouldn't think that anti-seize would be the way to go... I think it would just cause the gasket to get soggy... or way too slick to work with.
Old Nov 2, 2011 | 10:41 AM
  #34
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
RTV won't hold up to exhaust heat.
The metal gasket won't distort or squirm.
I don't care, it's done now. (on my truck)
Now if I could only keep my carburetor from flooding...
Old Nov 2, 2011 | 10:49 AM
  #35
lavatan's Avatar
lavatan
Getting back on point, usually a power valve will blow if you backfire out of the carb. Are you sure the timing is set correctly? I had a problem with my truck being too advanced and the exhaust valve would be opening when it was firing and *whoosh* fire out the carb. Set the back of my engine on fire once. So, yeah, had to replace the power valve after that. Just my .02
Old Nov 2, 2011 | 03:24 PM
  #36
beetle's Avatar
beetle
Because through personal experience, I have tried these gaskets with and without anti seize and have had a much better result in regards to gasket life.
Old Nov 3, 2011 | 08:20 PM
  #37
rockpile's Avatar
rockpile
Sorry guys Ive been pretty busy the last few days but I did get the gasket. It is a metal laminate one by felpro found at auto zone for about 6 bucks. The truck seems good go but I might lower the floats a tad more. Thanks to Ardwerkintruck for all the "leg work" and by the way It did blow out the "ear". Im going to drive the truck this weekend I will keep you posted.
astamp78
Apr 5, 2010 08:54 PM
CodaSmog
Mar 20, 2005 11:20 PM
matt77F2504x4
May 27, 2004 09:58 PM
jdawg78
Jul 2, 2002 04:54 PM
Bill_s351
Sep 15, 2001 09:15 PM
