power valves again!
Old Oct 16, 2011 | 01:29 PM
rockpile's Avatar
rockpile
bought the rebuild kit from holley this time, little more money but I think going cheap was my biggest mistake last time. we'll see how it goes when it gets here. Hopefully it doesn't take to long to get here.
Old Nov 1, 2011 | 08:58 PM
rockpile's Avatar
rockpile
finally fired up the 86 and it was not pretty. Had to jump start it and it ran terrible. The holley kit took forever to get here but it was worth the wait, the quality of the gaskets and rubber diaphragms far superior. It's cleaned, reassembled and ready to to go back in the truck. But when I went install it I realized the egr plate has a gasket under it that was totally destroyed. Maybe that was part of the problem in the first place? It was leaking pretty bad I think. I'm going to see if I can find one now. Anyone else made that oops before?
Old Nov 1, 2011 | 09:11 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I'm looking for that gasket right now...
No one seems to stock it.
The Dealer can't find the right one and says I have to buy 5 at $13 each
FelPro 60003 $5.71 on Amazon
Victor Reinz G27350 $1.50 @ RockAuto
Old Nov 1, 2011 | 09:54 PM
rockpile's Avatar
rockpile
That's ridiculous. I can't even figure out what it's called. But I'm gona keep tryin.
Old Nov 1, 2011 | 10:09 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
It's the lower EGR plate gasket...
Those aftermarket numbers are right.
If I have to buy 5 and you're still looking PM me your address...
Old Nov 2, 2011 | 05:28 AM
85lebaront2's Avatar
85lebaront2
Old School Hot Rodder
Jim, do you want me to see if my AutoZone commercial guy can get some of the Fel-Pro one?
Old Nov 2, 2011 | 06:46 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I'm off (on my bicycle) to the local Ford dealer to see if they got the right one today.
My AZ guy said they didn't warehouse it and they would bring it in *for an additional $15*.... on Friday.
Old Nov 2, 2011 | 07:32 AM
85lebaront2
Jim. my local AutoZone has it on the shelf, $4.99. I guess he keeps one for me.
Old Nov 2, 2011 | 07:55 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Well, I now have 4 extra E8TZ-9447-A / CG-536-B under plate gaskets.
This part was obviously updated after they stopped using carburetors in pickups.
(maybe for motor homes?)
I know chassis/driveline vehicles were using carbs until at least 1989.
They are a funny powdered pink looking material, not the heatproof laminated ones I'm used to seeing.
Anyway, rockpile, if you can't find one of the above numbers locally shoot me a PM with your street address and I'll send one out Priority Mail.
Old Nov 2, 2011 | 08:03 AM
85lebaront2
Yeah, Ricky said it shows 79-89 Ford coverage, probably 370-429 HD truck applications in addition to 460s. Glad you got it!
beetle's Avatar
beetle
Those gaskets come in 2 styles, I suggest the one that has a metal mesh sandwiched between the paper elements. It will last a lot longer than the plain paper element. I believe it is available at NAPA 5-6 bucks. Coat both sides with anti seize.
Old Nov 2, 2011 | 09:30 AM
1983F1503004x4's Avatar
1983F1503004x4
For most stuff that you can't find a gasket for, you can always make a gasket out of cork or whatever else material the auto-parts place has.
Old Nov 2, 2011 | 10:06 AM
  #28
ctubutis's Avatar
ctubutis
Why would one want to coat a paper gasket with anti-seize?
Old Nov 2, 2011 | 10:15 AM
  #29
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The EGR plate base gasket sees a lot of heat coming from the intake manifold's heated crossover.
They tend to burn out at the 'ear'.
I think Beetle was saying to coat the perforated metal -exhaust manifold type- gasket with anti seize.
I don't know why.
The pink gaskets I got were a new part in '88.
There must be a reason Ford decided to change to this material.
Old Nov 2, 2011 | 10:19 AM
  #30
Stangrcr1's Avatar
Stangrcr1
Prevents the gasket from sticking to the manifold or egr plate. Makes it much easier if you ever have to do the job again later.
