Power Valve
Old Jul 1, 2002 | 06:21 PM
jdawg78's Avatar
jdawg78
Power Valve
Hey guys is there a way to figure out what size power valve you need? My dad said you take vacuum measurements at idle and WOT and you do something with the number (he doesn't remember) to figure out what size power valve you need. I was thinking a 4.5 or a 5.0 but I don't want to jump in yet. I am at approx 6100 feet and I am a little rich, but I intend to order new jets along with the power valve. Thanx.
Old Jul 2, 2002 | 12:06 AM
Franklin2's Avatar
Franklin2
Power Valve
When do you have your rich condition? The power valve only contributes fuel when the vacuum goes low enough, as in pulling a hill or something. A rich cruising condition could only be fixed with the jets, unless you have a leaky power valve which would add fuel all the time, and this is a common thing to happen.
Old Jul 2, 2002 | 12:19 PM
teschwab's Avatar
teschwab
Power Valve
highest vacuum reading at idle and in gear. then divide that number by 2. for example 12/2=6. my understanding is that you don't want the power valve opening and closing during periods of idling. this will create a over rich problem. while you have the carb off consider installing the power valve protection piece if it hasnt already been installed.
Old Jul 2, 2002 | 04:54 PM
Lightning2Fast's Avatar
Lightning2Fast
Power Valve
2006powerstroke90
Jan 27, 2021 02:42 PM
Rusty_S
Aug 10, 2016 06:49 PM
59203shop
Apr 17, 2016 11:22 PM
mdgaf
Bronco II
Apr 16, 2013 09:01 PM
ChrisAdams
Oct 28, 2011 05:48 PM
