fuel line
Old Oct 10, 2011 | 10:33 AM
redman84's Avatar
redman84
Sounds like your fuel pump could be on it's way out. Low pressure and leaking from the weephole. If that is where it's coming from. Maybe someone else knows how low is significant of pump failure...
Old Oct 10, 2011 | 12:28 PM
lynches7.3's Avatar
lynches7.3
What should the pressure be at idling? I just got back from picking up a new pump. If its not raining when I get through eating lunch Ill see if I can rule this problem out. Thanks.
Old Oct 10, 2011 | 03:48 PM
lynches7.3's Avatar
lynches7.3
Hot dang boys I think we got it!! Got the new fuel pump on and as of right now I dont see any fuel in the valley or any dripping below. i drove the crap out of it and figured it would leak if it was going to. Ill check it again in a few days and if still no leak we'll call it a success. I would personally like to thank each of you who posted pictures and took time to answer my dumb questions.If you dont mind I would like yall to send me your email addresses and cell phone # so I can reach you at any given moment as Im thinking about opening my own diesel shop.LOL!!! That'll be the day. Thanks again.
Old Oct 11, 2011 | 09:21 AM
redman84's Avatar
redman84
Awesome man. Hope that gets it. No reason to go to a mechanic when you have FTE!!
FYI the fuel pressure should be 60-70 psi ideally at the valve on the side of the FPR. If it isn't high enough there's a trick for that too.
Old Oct 11, 2011 | 10:08 AM
lynches7.3's Avatar
lynches7.3
Ok whats the trick. I checked the pressure at idle after I installed the new pump and still was only getting the mid 40's. Just assumed it had air in it. Was going to check it again in a couple of days to see if it was any different.
Old Oct 11, 2011 | 10:20 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Look here
https://www.ford-trucks.com/forums/1...-fpr-shim.html
Old Oct 13, 2011 | 12:14 PM
Fullcrew7.3's Avatar
Fullcrew7.3
Thanks for the link Jim. My fuel hoses are NASTY! Gonna pick up new ones this afternoon. Not to mention a new serpentine belt.
1979 300i6
Jul 3, 2014 11:20 PM
Wicked Endings
13
Feb 9, 2011 07:04 PM
89F20plowtruck
May 18, 2010 04:52 PM
menmy02x
Feb 23, 2009 08:46 PM
