How deep can you safely deck a block?
Old Oct 9, 2011 | 01:27 AM
nothercrash's Avatar
nothercrash
I'm talking about a 400, with pistons that currently sit about .077" down in the hole.
I want to deck the top of each cylinder bank. The goal is to raise compression, I'm not going for any quench stuff, so I can mill the head bottoms slightly too.
For the cam I'm trying to run, I need to dump a bunch of that .077 height, like .040" or more, even if I advance it 4*.
The calculations I've done up to now include a .04" thick head gasket, but if I could only take off a total of .040" deck height (say, .02" off the heads, .02" off the block), I would have to go to a .021" gasket. I'd LIKE, therefore, to take out as much deck height as possible in iron, so I can run a normal thickness (cost) head gasket.
How deep can you go in a block before you hit water, get so thin you get temp issues, or compromise strength? Same for a head (open chamber, M head)?
Also, what's the general rule of thumb for how much you can take off without having to modify an intake because the heads sit tighter together now? Same question for pushrods since you can only shim the rockers to a certain point.
Thanks for any info you guys can give me, just brainstorming a little bit tonight.
AleX
Old Oct 9, 2011 | 04:28 PM
cj06's Avatar
cj06
you would be better off getting a newer set of pistons than going threw all that work !
also look into a set off copper head gaskets !
Old Oct 9, 2011 | 06:17 PM
nothercrash
Well I've thought about that, but these are already flat tops with just a 3cc valve relief.
A custom set would be a ton, and I don't know of anyone who makes any with domes. I could think about bushing in some 351C pistons I guess, but this wasn't meant to be a total rebuild, just top end.
I could also probably get my rods metalled up and redrilled slightly off center, to get the pistons to top out a little higher, but that's no great solution either.....
What's going on is I was supposed to get some Aussie heads in a trade from all the way back in April, and the guy finally pops em off his motor last weekend, and they're open chamber....... Needless to say I wasn't pleased, but now I'm just trying to make something work. The bottom of my engine is fine, and so is the top in fact, but this was gunna be a nice upgrade of my current open chambers.
Old Oct 9, 2011 | 09:55 PM
cj06's Avatar
cj06
check this guy out
TMeyer, Inc. Precision Automotive Machining
http://www.fordmuscle.com/archives/2008/06/400MockUp/
Old Oct 9, 2011 | 10:15 PM
meborder's Avatar
meborder
Could you offset grind the crank some?
That would bring the pistons up at TDC. Perhaps with a moderate offset and a moderate decking job you could get the pistons up out of the hole?
just throwin' out ideas.
Old Oct 9, 2011 | 10:33 PM
cj06's Avatar
cj06
the crank can be off set ground but then you are getting into other areas that can be trouble , custom rods , will the stock pistons pull threw the bottom ,
Old Oct 10, 2011 | 01:34 AM
nothercrash
Border, yes I could either offset grind the crank or do essentially the same by offset resizing the rods, but like CJ says, that would just invite all sorts of other weird issues with clearance, balance, and strength.
I thought of sneaking up the main (crank) bore just slightly too (.1"), but that would screw up the timing chain, and front and rear seals.
And CJ, I know Tim Meyer's site well haha, but his pistons don't offer me enough compression. I'm trying to run a fairly long duration cam, and I need a static CR of over 10.5:1.
Old Oct 10, 2011 | 02:27 AM
cj06's Avatar
cj06
have you thought about using a different rod ?
Old Oct 10, 2011 | 05:06 AM
xran's Avatar
xran
yep longer rod will give you more compression, with the same bore/stroke/deck height.
I'm "told" that a 350 rod or even one from the 360 (mopar) will bump up compression... just to throw something else into the mix for you - why not leave compression down and throw 10psi on a blower at it instead? nothing beats blower whine!
Pkupman82
19
Mar 24, 2020 09:28 PM
Mikulh
Aug 22, 2018 02:46 PM
1960fordf350
Jul 11, 2015 08:47 AM
Huntersbo
Feb 20, 2011 06:25 AM
luckydoggy
Nov 20, 2008 10:20 AM
