compression question
Old Nov 18, 2008 | 07:44 PM
luckydoggy's Avatar
luckydoggy
Im building a 351W and the pistons I have are listed as 9:1 when using a 64cc head. Can anyone tell me what my compression would be if I used the same pistons with a 58cc head? I want to be able to run pump gas but there are alot more aftermarket aluminum heads with the smaller chambers. I realize that I should have picked the heads first and then matched the pistons for the desired CR but that not the way it happened. I put the cart before the horse and now Im trying to see if I can keep the pistons, or if Im going to be shopping for new ones. Any help, advice, or info is appreciated!
Old Nov 18, 2008 | 08:33 PM
Kuskoal's Avatar
Kuskoal
check this out
Engine Compression Ratio (CR) Calculator
this will let you plug in all the values like chamber size, bore diameter, head gasket thickness and others to find almost the exact compression ratio. Pretty neat if you ask me
Old Nov 18, 2008 | 08:38 PM
luckydoggy's Avatar
luckydoggy
Originally Posted by Kuskoal
check this out
Thanks. I will check it out. Im not sure about the head gasket thickness or some of the other values they want to know. I guess I'll have to figure that stuff out. I guess Im kind of looking for a ballpark figure. Something like; for every cc point drop you get approx. .2 increase in compression. 64cc head = 9:1 so 62cc head = 9.4:1 I know thats not an accurate # but thats kind of the info Im looking for. I dont know if you can even figure it that way but I figured I would ask rather than trying to figure out swept volume, gasket thickness, ect...
Old Nov 18, 2008 | 11:04 PM
Conanski's Avatar
Conanski
If you search online you'll find specs for head gaskets which includes compressed thickness and bore diameter. I put 0.032 in for thickness, 4.06 for gasket bore, -19.5cc for piston dish(or valve eyebrow volume), and 0 deck height. This results in 8.98 CR with 64cc heads and 9.55 CR with 58cc heads using stock engine bore and stroke. This will run fine on pump gas if you make a point of filing down any sharp edges in the combustion chambers, the edge around the head gasket surface are often very sharp after machining.
Old Nov 19, 2008 | 12:44 PM
luckydoggy's Avatar
luckydoggy
Thanks Paul. I've been trying to decide between those FRPP X303 heads and some AFRs. I just wanted to make sure I was staying under 10:1. If I go with the AFRs, do you think I should go 165 or 185? Im just looking for good street performance, no racing. I think they offer them in 60cc so that would be about perfect. Thanks!
Old Nov 20, 2008 | 10:20 AM
Conanski's Avatar
Conanski
The AFR heads are sweet but they're twice the price of X303 or the Dart Iron Eagles.. which are cheaper than either but fall between them in airflow. I have a set with 2.02/1.60 valves for my 5.8 build...
jamies460
Aug 10, 2009 02:19 PM
1972 Ford Thunderbird 429 V8
Dec 19, 2008 05:42 PM
1963f100
May 9, 2007 03:50 AM
fried_guy
4 Cylinder Engines
Oct 29, 2004 06:54 PM
wtroger
Nov 11, 2001 10:59 AM
