IP removal
Old Oct 8, 2011 | 07:06 PM
Jayme Duty's Avatar
Jayme Duty
IP removal
I am in the process of changing out IP and injectors, Does anybody have any tips to get the two lower 9/16 bolts off of the injection pump
Old Oct 8, 2011 | 07:28 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
i got a cheapo wrench and just cut it to a suitable length. then i went over to the bench grinder and ground the head on the open end side until it fit. don't grind to much or you loose strenght in the wrench.
Old Oct 8, 2011 | 07:56 PM
damac's Avatar
damac
I have seen enough people mention the need for a special wrench that is just for these trucks and will cost $$ Or if you have the ability to take existing wrenches and rebend/grind them to the shape needed. Somebody else will have to chim in on that one.
With that being said I am wondering if you tried it yet? For whatever reason on the truck in my sig I have been able to alternate between a couple 9/16" open ended wrenches that were different sizes and with the fuel return hard rail disconnected from the pump and its hold down brackets.
I haven't had a problem yet and have dealt with a couple pumps on this truck this far. When one wrench ran out of room I was able to start another and angle it in a way to give me the throw I needed to loosen and tighten.
akamacgyver's Avatar
akamacgyver
Clueless spectator!
Make a wrench
Most guys use a 9/15 combo wrench and do as 94IDI says and grind it down to fit. I personally used the closed end since it is 12 point and you can get more degrees of turn from it. A lot of people will tell you that they were able to get them off and on with a regular wrench, but do yourself a favor and make one and store it because you will likely need it again in the future. Do a search in this forum for "wrench" and I bet you will find some pics of what other people did.
Good luck,
Mac.
Old Oct 8, 2011 | 08:27 PM
Jayme Duty's Avatar
Jayme Duty
thanks guys. I did grind my wrench down and was able to get it off. Now i have more questions. Since i swapped in a zf5 i do not need the TPS and can leave it disconnected, correct or not. Also i bought new copper washers for the injectors but cannot get the old ones off. Do i need new washers. I should also mention the pump and injectors are used, they have 2000 miles on them.
Old Oct 8, 2011 | 08:29 PM
Jayme Duty's Avatar
Jayme Duty
Also would i be safe turning the pump up a flat before i install it. Only cause it easier while on the bench.
Old Oct 8, 2011 | 08:35 PM
86f250XLT-4x4's Avatar
86f250XLT-4x4
It's not much harder to do it on the truck and did the po turn it up?? And I soaked my injectors in a degreaser for a couple days and with a knife they came right off no problem
Old Oct 8, 2011 | 09:35 PM
Jayme Duty's Avatar
Jayme Duty
I do not believe the pump has been turned up because the little blob of gray paint is unbroken
Old Oct 8, 2011 | 10:51 PM
LSO1123's Avatar
LSO1123
I did the same thing except I cut the open side off when I cut it to a usable length and ground the box side down to make it thinner so that it would fit on the nuts. It was free and it works like a charm!
Old Oct 8, 2011 | 11:00 PM
86f250XLT-4x4
Well since it's not turned up I don't see why not just be careful on how far you do if you don't have a pyro... I think that's why mine failed
Old Oct 8, 2011 | 11:38 PM
bio-d's Avatar
bio-d
I just pulled mine off yesterday, no special wrench needed, but I think I was just lucky. We'll see how it goes in.
I remember someone here was selling custom IP wrenches, but they were something like $40+.
Mike
Old Oct 9, 2011 | 12:53 AM
Aune163rd's Avatar
Aune163rd
THat pump was not turned up jayme, so i would definitly recommend doing it.
Old Oct 9, 2011 | 10:00 AM
eatont9999's Avatar
eatont9999
I used a crow's foot wrench with a swivel and some small extensions. It was a B*** but I eventually got it out. Take off the #8 line before you lift it out and it will not catch on the firewall/vac lines. Take off the #7 too if you can reach it.
Old Oct 9, 2011 | 10:31 AM
Jayme Duty's Avatar
Jayme Duty
i got it out last night without removing any lines but it was not easy. I also got all return lines and injectors out, i did screw them back in just a little to keep anything from falling in. I am going out now to try and tackle getting everything back together. If all goes well i will be going for a test drive by noon. However i have had projects like this before where it was noon three days later when i finally test drove it.
Old Oct 9, 2011 | 10:37 AM
Aune163rd's Avatar
Aune163rd
jayme, your gonna be fine, it should just go right in.
