Vacuum Delete
Old Oct 8, 2011 | 04:39 PM
thefordman1992's Avatar
thefordman1992
Vacuum Delete
On my 85 f150 with the 351 ho with an edelbrock performer carb, is there any vacuum lines i can delete. I just hate the mess of vacuums under the hood.
Old Oct 8, 2011 | 05:06 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
What functions do you want to lose???
Do you need to pass emissions wherever you live?
There should be a sticker on your radiator support telling you where all the color coded lines are connected to.
Old Oct 8, 2011 | 05:10 PM
thefordman1992
No i do not need to pass an emissions test. Ive looked at the sticker but im not sure what i can delete and what i cant. I dont want to just start deleting then my truck not run properly any longer.
Old Oct 8, 2011 | 05:24 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Well, they certainly didn't put all that **** on there for no reason.
Old Oct 8, 2011 | 05:33 PM
thefordman1992
Thats very true. Ive heard of people doing smog and vacuum deletes but ive never tried it.
Old Oct 8, 2011 | 05:36 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Do you have the stock intake manifold, or the NON-EGR performer manifold to go with your carb?
Do a search for "351 emissions delete" there are a bazillion threads on this.
Old Oct 8, 2011 | 05:38 PM
thefordman1992
Stock manifold.
Old Oct 8, 2011 | 05:49 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Hard to lose the EGR then, it's covering a hole in the exhaust.
There's lots of people on this board who have deleted the A.I.R. pumps and the plumbing across the back of the heads.
Charcoal canisters and purge plumbing, EGR etc..
But you need to keep the lines for the Distributor, PCV, heater controls and air cleaner(if it's stock)
Old Oct 8, 2011 | 05:53 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Scratch that.... you live in Florida and probably don't need a functioning heat riser in the air cleaner.
Old Oct 8, 2011 | 06:29 PM
thefordman1992
Well i dont live in florida. I live in missouri. The smog pump has been deleted on the truck already.
Old Oct 8, 2011 | 06:48 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Well, if all that's gone, what lines are left?
Old Oct 8, 2011 | 06:55 PM
Sw1tchfoot's Avatar
Sw1tchfoot
It sounds like half of your stuff is already missing. If the stuff was still there, I wouldn't touch it.
To put it simply, the PCV and Vacuum Advance system are the two things that you should not remove. The EGR can stay or go, it doesn't really matter. If it is functioning correctly and connected correctly I would leave it.
James Wagoner
18
May 19, 2018 12:11 AM
claytonk
Feb 21, 2012 11:49 PM
greybullit
20
Feb 19, 2006 08:33 PM
bow249
Oct 24, 2004 11:47 AM
tygarcia
1978 - 1996 Big Bronco
May 11, 2004 08:47 AM
