Sponsored by: Auxito
newbee heat issue ?
Old Oct 8, 2011 | 03:44 PM
tc3457's Avatar
tc3457
newbee heat issue ?
99 f150 heater only blows warm, checked heater hoses they are both hot, I believe it is a blend door issue, when I turn temp dial to cool it will blow cool, but when turned to hot it is only warm, my question is where is the blend door located? any tips Thanks
Old Oct 9, 2011 | 10:41 AM
86f350's Avatar
86f350
If I remember right it's under the dash on the passenger side. Try having someone turn the temperature control and listen for the door to open/ close to pinpoint it. I know this probably isnt much help but it's all I've got at the time.
Old Oct 9, 2011 | 01:47 PM
00GT's Avatar
00GT
Do a search on here "blend door" there's lots of info about it. Or Google it its a fairly common issue with the f150s theres also a repair kit for it so you don't have to remove the dash.
Old Oct 9, 2011 | 06:03 PM
steve(ill)'s Avatar
steve(ill)
read the bottom post about "glove box access"--- i have not done this.
https://www.ford-trucks.com/forums/1...lend-door.html
jrh32
Dec 19, 2016 11:14 PM
joners
May 24, 2010 06:07 PM
blackstroker
Nov 24, 2009 04:53 AM
Sleblanc
Jul 9, 2006 09:26 PM
wil057
Feb 1, 2004 11:45 PM
