hard shifting
Old Oct 8, 2011 | 12:22 PM
powersmoked's Avatar
powersmoked
hard shifting
Truck has newerslave, pp, clutch. MC is full. No leaks. Shifting toughest going into 2. I can see my slave moving a good 5/16". I had cheopo ATF in it. I just swapped in mobil 1 FS ATF anda little Lubeguard red. It is much better. Are my synchros bad. Are they hard to change. Any thoughts?
Old Oct 8, 2011 | 02:26 PM
michigan66's Avatar
michigan66
The tranny in my former '91 was starting to have shifting problems. The problem was most noticable when shifting into 1st gear while stopped. I could get into 1st gear very smoothly if the truck was moving at all. When stopped, I would try to go back and forth between 1st and 2nd and the mechainism seemed blocked each way. Again, this did't happen every time when I was stopped and tried to get into 1st gear. It just happened from time to time - just often enough to be aggravating. It seemed to me that the shift rail would not move. I would get a jerk from the transmission as though the whole thing moved. I was fairly certain that the clutch was working properly, so i came to the conclusion that the problem was caused by a bad 1-2 synchronizer.
I know repair kits are available and I have seen descriptions of how to disassemble the transmission. But it looked like more of a project than I wanted to tackle by myself. If I has the right parts and felt like I knew what I was doing, the job could be done in an afternoon - that excludes removal and reinstallation of the transmission. I did consider looking for a used tranny, putting that in the truck and then experiment rebuilding the tranny that was originally in the truck, doing it at my leisure.
That's not much of a specific answer to your question, but it does give some things to condsider as you work toward a decision.
Old Oct 8, 2011 | 10:11 PM
cj06's Avatar
cj06
might try changing the oil in the tranny with some synthetic stuff ! what tranny do you have ?
Old Oct 9, 2011 | 05:19 AM
powersmoked
as I mentioned in my first post.....I did a drain and fill and used Mobil full synthetic ATF, $10 a quart..........it is much much better with the Mobil 1 in but still a little off........I am going to guess the syncrhros are worn. I will just drive it till it gives out, maybe keep my eye out for a used M5OD.
Old Oct 9, 2011 | 04:37 PM
michigan66's Avatar
michigan66
Picking up a used one was my thought at the time. But then it occured to me that, if mine had this problems at about 90 K miles, a used one could that the same number of miles or more and I soon would have two poorly shifting trannies.
Old Oct 10, 2011 | 08:46 AM
76supercab2's Avatar
76supercab2
Why not buy a used one, rebuild it, then install it in your truck?
Old Oct 10, 2011 | 09:07 AM
02FX45.4's Avatar
02FX45.4
Does the transmission make a whining noise in any of the gears?
Old Oct 10, 2011 | 09:24 AM
grumpy hvacr's Avatar
grumpy hvacr
I occasionally have a problem with getting the truck into gear. Double clutching a few times seems to help.
Old Oct 10, 2011 | 06:55 PM
97ranger xlt's Avatar
97ranger xlt
i have that same deal.. mine has dino in it..
it did help to change the fluid though especially in the cold weather..
Old Oct 11, 2011 | 04:32 AM
powersmoked
I put the Mobil 1 FS, $10 a quart in on Thursday it is 1000% better.........it might be worth the money for you. I also had 3 ounces of lubegurd Red around that I put in but I am not sure if that did anything
pfb
Jan 31, 2007 11:34 AM
MustangGT221
Dec 15, 2005 09:32 PM
pintopower8
Jan 31, 2005 11:51 PM
wickymustang
Apr 18, 2004 09:44 PM
Drive
Feb 24, 2004 09:24 PM
