Engine Getting Hot
Old Oct 8, 2011 | 10:39 AM
midsouth's Avatar
midsouth
Engine Getting Hot
My truck temperature runs fine until I turn on the cabin heat. Why does the engine temperature rise when I do this?
Old Oct 8, 2011 | 07:27 PM
Franklin2's Avatar
Franklin2
Are you sure it's not a electrical problem with the gauge? Possibly reacting to the load of the blower fan? I would put a real temp gauge on it from the store before worrying about it, unless you have other signs the engine is really getting hot.
Old Oct 9, 2011 | 05:36 AM
midsouth's Avatar
midsouth
Good point. Normally the engine temp will lesson with the heat on...I'll look into the guage and wiring. Thank you.
Old Oct 9, 2011 | 07:25 AM
f100jim's Avatar
f100jim
Make sure you have a good solid ground connection between the engine block and the body. If you have the factory oil pressure gauge, check to see if its needle goes up with the heater blower on.
bowhunter96
Sep 15, 2021 07:05 AM
wareagle8403
Jan 27, 2012 11:03 AM
drunkenrich
Dec 21, 2009 04:45 PM
pjizzo
Dec 22, 2004 05:16 AM
klf
Mar 11, 2003 08:38 PM
